Need vb5 program to read files
Does anyone have a vb5 program that opens a file and reads it?
I am very a pro at vb pro but the new vb is a pain
It would save me a few hours if someone could share the new vb program.
Thanx
Don
······· "What do you mean, it doesn't have any tubes?"
······· "No such thing as a dumb question" unless it's on the internet
Thanx
Don
Private Sub GetFile(fname As String) Dim FileNo As Integer Dim FileName As String Dim FileName2 As String Dim FileSize As String Dim line As String Dim lines As String Dim i, j As Long Dim bytes() As Byte Dim txt As String Dim b As Byte Dim z As Integer FileNo = FreeFile ' FileName = "D:\Propeller\ZiCogFiles\CPM_64KB.RAM" FileName = fname txtStatus.Text = "Opening..." & FileName txtStatus.Refresh FileSize = FileLen(FileName) ' Returns file length (bytes). ReDim bytes(0 To FileSize - 1) ' make correct size Open FileName For Binary As FileNo Get FileNo, , bytes ' gets complete binary file Close FileNo txtStatus.Text = "File loaded" txtStatus.Refresh▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
· Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
· Search the Propeller forums (via Google)
