ADC reference higher than Vdd — Parallax Forums
Bobb FwedBobb Fwed Posts: 1,119
edited 2009-06-17 19:57 in Propeller 1
I haven't had time to look through the datasheet completely, but I didn't see anything on my brief read through. Does anyone know, can you give the MCP3008 (10-bit version of the MCP3208) reference pin a higher voltage than the input (Vdd)? The concept I have is to put a 4.096V reference on the reference pin. I am powering the IC with 3.3V. I could put a 2.5V reference, but I have found that the output voltages is less consistent over wide temperature ranges than the 4.096V reference ICs, not to mention the 4.096V ones are much more common.
Datasheet
April, 2008: when I discovered the answers to all my micro-computational-botherations!
  • LeonLeon Posts: 7,620
    edited 2009-06-16 20:36
    If you read the data sheet you will probably see that you can't have any input higher than Vdd.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • Bobb FwedBobb Fwed Posts: 1,119
    edited 2009-06-16 20:43
    Duh...I was just blind the first time I read through it: "All inputs and outputs w.r.t. VSS .....-0.6V to VDD +0.6V"
    I was already typing "It is usually limited to some diode's forward voltage higher than Vdd"...and there it was.
    ...so probably (at best) limited to 3.9V reference...but that doesn't really exist...so I am stuck with the 2.5V.
    edited 2009-06-16 20:50
    Bobb Fwed said...
    Why not just power the chip with your 4.096V, and then use the correct voltage dividers on all the lines that communicate with the 3.3v device.
    I did this when I had to operate a 3.3v lcd with a 5v microcontroller.
    TERMS OF USE: MIT License
    "Permission is hereby granted, free of charge, to any pers...........................
    ..............................OMITTED FOR FORUM...............................................
    .................. OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. "
    edited 2009-06-16 21:01
    The reference IC isn't designed to be a power supply.
    I did consider powering the ADC at 5V (already have a 5V circuit on the board) then reference at 4.096. But I don't have much room left on the board...I'd have to redesign almost the entire board to make room for the resistors between the ADC and the prop.
    edited 2009-06-16 21:23
    Bob,
    If it's the same board you posted in the other thread, you'd have plenty of room if you changed your passives to surface-mount.
    edited 2009-06-16 21:43
    No, it is a smaller board. As of right now, I am doing much by hand and I don't know if I want to mess with a lot of small SMT pieces...
    edited 2009-06-16 22:04
    Bob Fwed said...
    It's definitely a speed bump, but the anticipation is much worse than the reality. With a stencil for applying the solder and an infrared toaster oven to reflow, things can go quite smoothly. Here is a thread that relates my experiences with Zephyrtronics' solder paste and Ryan O'Hara's stencils.
  • TubularTubular Posts: 4,774
    edited 2009-06-17 03:16
    If the voltages you are interested are in the low-middle of that range, you can use a Blue LED as a simple voltage limiter. It kicks in around 3 volts and has the benefit of visual indication. I do this with the MCP3304.
    edited 2009-06-17 04:28
    Phil Pilgrim (PhiPi) said...
    Bob Fwed said...
    I would have to say that smt soldering is not that easy. You do need a precise temp gun, and if you have bad eyes, then you most def need a microscope. smt soldering sucks when you SCREW UP. bridged pins suck. .,,,, they suck.
    edited 2009-06-17 04:59
    I don't get bridged pins with drag-soldering. The secret is plenty of jelly flux and a mini-hoof cartridge on my Metcal soldering station.
    Leon
    edited 2009-06-17 05:56
    For the first time in my life (and ever since), I did not get any bridged pins by using a solder stencil and the Zephyrtronics solder. Soldering with an iron is definitely not the way to go. Solder paste, a stencil, and a reflow oven (~$99 from Costco) is. It's almost goof-proof. Save the iron for the through-hole stuff.
    edited 2009-06-17 15:18
    Tubular said...
    Are LEDs consistent enough of a forward-voltage drop (I mean from one LED to another)?
    I think a better choice would be a 0.1% tolerance resistor voltage divider. Then I could customize exactly what the reference voltage is.
    The LEDs can be a very good match within the same batch. Their advantage is they don't reduce the source impedance around say 2 volts. Thats not always important though.
    The right solution really depends on the nature of your input signal. Is in centred on 2 volts? Is it buffered / driven with a low source impedance? You mention a wide temp range - I assume this is important.
    Also you can run the adc off 5 volts and interface in to the prop via resistors. It can sample faster at 5v.
    tubular
