Current Rating across all Pins on SX28AC/DP...
I have a simple question (I think), but I just can't find the answer.
I know that the SX28AC/DP has 45ma rating per output pin, but·what is the MAX ma's across all pins?
Example: BS1 allows 20ma per pin with a MAX of 40ma across all pins.
So as long as you don't go over that (including current used for clocking the SX itself) you should be okay.
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
I guess it really doesn't matter because I need to load it with 140mA across the pins, so I am going to use a few transistors.
If I am reading this correctly, I can deduct 8mA when I have my clocking set to 4MHz. Correct?
