Parallax GPS Receiver Module #28146 I/O
                    We are using your GPS module item no. 28146.
is any h/w is needed to interface the pin 3 "SIO" to 3.3v logic (e.g., Coridium wireless - www.coridiumcorp.com). In particular is a current limiting resistor required? Is that sufficient? What should it's value be and what if any other level shifting or other protection is needed?
Is there any danger if the connection doesn't revert to an input quick enough that damage could occur to the GSP module through pin 3?
Can you provide an equivalent circuit for pins 3 and 4?
Parallax Engineering
Like all TTL if you are connecting directly to a 5V power supply you must use a limiting resistor.
The wireless board can be powered from a regulated 5V wall wart, which would then be able to supply power to the GPS module.
