First Boe Bot program modification problem.
· I am trying to add a section that witll enable a Parallax 5 button R/C control to be used with the roaming with ping with infrared program. The original IR sensors were changed to Sharp sensors with a compartor to a simple TTL on off signal. Works fine. Now trying to add a wireless simple 5 button board to override the roaming program when used. The R/C reciever also works fine with a simple Hi Lo output for each channel. I thought it would be simple. The boe bot book is very basic and and not much imfo on modifications I guess. Mabe you guys can steer me in the right direction. Thanks. So happy my first monster bot is finally moving. Enclosed is a copy of the program I am trying to add on to.
Main:
DO
' Start R/C program insert
IF (IN1 = 1) THEN
GOSUB Turn_Left
ENDIF
IF (IN2 = 1) THEN
GOSUB Back_Up
ENDIF
IF (IN3 = 1) THEN
GOSUB Turn_Right
ENDIF
IF (IN5 =1) THEN
GOSUB Forward_Pulse
ENDIF
IF (irDetectLeft = 0) AND (irDetectRight = 0) THEN
GOSUB Ping_Around ' Object Detected via IR Forward
ELSEIF (irDetectLeft = 0) THEN
GOSUB Ping_Around ' Object Detected via IR Left
ELSEIF (irDetectRight = 0) THEN
GOSUB Ping_Around ' Object Detected via IR Right
ENDIF
counter = counter + 1 ' Increment Passive Counter
IF counter > 10 THEN ' Wait For 10 Servo Pulses
GOSUB Ping_Out ' Activate PING)))
ENDIF
IF (distance > 30) THEN ' Is Object Farther Than 30 cm?
GOSUB Forward_Pulse ' If Yes Go Forward
ELSE
GOSUB Ping_Around ' Otherwise Scan For Clear Path
ENDIF
LOOP
Jax
If a robot has a screw then it must be romoved and hacked into..
