Scroll function
Hello
I'm trying to make a scroll function for the 4x20 lcd
When i send a string it will be copied to display[noparse][[/noparse]4]
during a scroll every line scrolls up, and the display[noparse][[/noparse]4] line shows in the LCD
but when i send another string, the screen scrolls up like it has to do, but the last 2 lines have the same text. (last send string)
And i'm not know what i'm doing wrong here
example
first time i start the program
output to lcd
1
2
3
4
now i send "PARALLAX"
displays shows
2
3
4
PARALLAX
send another string: "JAVELIN"
display shows now:
3
4
JAVELIN
JAVELIN
Post Edited (Tumbler) : 6/14/2009 10:40:05 AM GMT
public static void main() { Uart txOut = new Uart(Uart.dirTransmit, LCD_PIN, Uart.dontInvert, Uart.speed19200,Uart.stop1); Serial_LCD4x20 myLCD = new Serial_LCD4x20(txOut); myLCD.clearDisplay(); String [noparse][[/noparse]] display; display = new String[noparse][[/noparse]5]; display[noparse][[/noparse]0] ="1 "; //lcd module line 1 display[noparse][[/noparse]1] ="2 "; //lcd module line 2 display[noparse][[/noparse]2] ="3 "; //lcd module line 3 display[noparse][[/noparse]3] ="4 "; //lcd module line 4 display[noparse][[/noparse]4] =" "; // StringBuffer buf= new StringBuffer(255); boolean scroll=false; while(true){ // endless loop while(rxUart.byteAvailable()){ // look if received data char c=(char)rxUart.receiveByte(); // get the data buf.append(c); // and put into buffer scroll=true; } display[noparse][[/noparse]4]=buf.toString(); //copy buf to display line 4 buf.clear(); // empty the buffer if(scroll){ //scroll display array for(int i=0;i<4;i++){ System.out.println("Copy display line ("+(i+1)+") to display line ("+i+"):"+ display[noparse][[/noparse]i+1]+"->"+display[noparse][[/noparse]i]); display[noparse][[/noparse]i]=display[noparse][[/noparse]i+1]; // copy display line i+1 to display line i }//end for // copy display array into lcd for(int i=0;i<4;i++){ myLCD.setPosition(i,0); myLCD.write(display[noparse][[/noparse]i]); }// end for scroll=false; }//end if(scroll) }//end while }//end main
example
output to lcd
1
2
3
4
displays shows
2
3
4
PARALLAX
display shows now:
3
4
JAVELIN
JAVELIN
rather than the string contents.
You need to rotate the string pointers (better use string buffers)
[/code][/size]
regards peter
