I want to combine the compass with the line follower, so at those two points on the picture my robot turn right/left with 90 degrees, go straight, turn back and continue to follow the line. I did this without the compass but now I want to use the compass.
This is my code without the compass:
' {$STAMP BS2}
' {$PBASIC 2.5}
qtis VAR Nib
counter VAR Word
OUTB = %1111
DO
GOSUB check_qtis
SELECT qtis
CASE %1000
PULSOUT 13, 670
PULSOUT 12, 670
CASE %1100
PULSOUT 13, 750
PULSOUT 12, 670
CASE %0100
PULSOUT 13, 790
PULSOUT 12, 670
CASE %0110
PULSOUT 13, 800
PULSOUT 12, 700
CASE %0010
PULSOUT 13, 830
PULSOUT 12, 710
CASE %0011
PULSOUT 13, 830
PULSOUT 12, 750
CASE %0001
PULSOUT 13, 830
PULSOUT 12, 830
CASE %0111
FOR counter = 1 TO 33
PULSOUT 13, 780
PULSOUT 12, 780
PAUSE 20
NEXT
FOR counter = 1 TO 58
PULSOUT 13, 750 + counter '820
PULSOUT 12, 750 - counter '680
PAUSE 20
NEXT
FOR counter = 58 TO 1
PAUSE 20
NEXT
FREQOUT 3, 2000, 3000
FOR counter = 1 TO 60
PULSOUT 13, 750 - counter '680
PULSOUT 12, 750 + counter '820
PAUSE 20
NEXT
FOR counter = 60 TO 1
PAUSE 20
NEXT
FOR counter = 1 TO 30
PULSOUT 13, 720
PULSOUT 12, 720
PAUSE 20
NEXT
FOR counter = 1 TO 35
PAUSE 20
NEXT
CASE %1110
PULSOUT 13, 720
PULSOUT 12, 720
PAUSE 20
NEXT
PAUSE 20
NEXT
PAUSE 20
NEXT
PAUSE 20
NEXT
PAUSE 20
NEXT
FOR counter = 1 TO 32
PULSOUT 13, 780
PULSOUT 12, 780
PAUSE 20
NEXT
PAUSE 20
NEXT
I want to use the averaging code for the compass, wich is this:
[noparse][[/noparse] Title ]
' Smart Sensors and Applications - TestCompassAveraged.bs2
' Test to make sure Hitachi HM55B Compass Module is working.
' {$STAMP BS2}
' {$PBASIC 2.5}
[noparse][[/noparse] I/O Definitions ]
DinDout PIN 13 ' P2 transceives to/from Din/Dout
Clk PIN 12 ' P0 sends pulses to HM55B's Clk
En PIN 11 ' P2 controls HM55B's /EN(ABLE)
[noparse][[/noparse] Constants ]
Reset CON %0000 ' Reset command for HM55B
Measure CON %1000 ' Start measurement command
Report CON %1100 ' Get status/axis values command
Ready CON %1100 ' 11 -> Done, 00 -> no errors
NegMask CON %1111100000000000 ' For 11-bit negative to 16-bits
Negative CON 1 ' Word.bit15 = 1 -> negative
Positive CON 0 ' Word.bit15 = 0 -> positive
[noparse][[/noparse] Variables ]
x VAR Word ' x-axis data
y VAR Word ' y-axis data
status VAR Nib ' Status flags
angle VAR Word ' Store angle measurement
mCount VAR Nib ' Measurement count
xSum VAR Word ' x-axis measurement accumulator
ySum VAR Word ' y-axis measurement accumulator
sign VAR Bit ' Sign bit
[noparse][[/noparse] Main Routine ]
DO ' Main loop
GOSUB Compass_Get_Axes ' Get x, and y values
angle = x ATN -y ' Convert x and y to brads
angle = angle */ 361 ' Convert brads to degrees
DEBUG HOME, "x-axis N(-S) = ",SDEC x, ' Display axes and degrees
CLREOL, CR, "y-axis W(-E) = ",
SDEC y, CLREOL, CR, CR, "angle = ",
DEC angle, " degrees", CLREOL
PAUSE 150 ' Debug delay for slower PCs
LOOP ' Repeat main loop
[noparse][[/noparse] Subroutine - Compass_Get_Axes ]
Compass_Get_Axes: ' Compass module subroutine
xSum = 0 ' Accumulators to zero
ySum = 0
FOR mCount = 1 TO 10 ' Take ten measurements
HIGH En: LOW En ' Send reset command to HM55B
SHIFTOUT DinDout,clk,MSBFIRST,[noparse][[/noparse]Reset\4]
HIGH En: LOW En ' HM55B start measurement cmd
SHIFTOUT DinDout,clk,MSBFIRST,[noparse][[/noparse]Measure\4]
status = 0 ' Clear previous status flags
DO ' Status flag checking loop
HIGH En: LOW En ' Measurement status command
SHIFTOUT DinDout,clk,MSBFIRST,[noparse][[/noparse]Report\4]
SHIFTIN DinDout,clk,MSBPOST,[noparse][[/noparse]Status\4] ' Get Status
LOOP UNTIL status = Ready ' Status ready? Exit loop
SHIFTIN DinDout,clk,MSBPOST,[noparse][[/noparse]x\11,y\11] ' Get x & y axis values
HIGH En ' Disable module
IF (y.BIT10 = 1) THEN y = y | NegMask ' Store 11-bits as signed word
IF (x.BIT10 = 1) THEN x = x | NegMask ' Repeat for other axis
xSum = xSum + x ' Keep a running sum of x
ySum = ySum + y ' Keep a running sum of y
NEXT
sign = xSum.BIT15 ' Store sign of xSum
xSum = ABS(xSum) ' Take absolute value
x = xSum / 10 ' x = the average measurement
IF xSum // 10 >=5 THEN x = x + 1 ' Fraction > .5? Round up
IF sign = Negative THEN x = - x ' if xSum negative, negate x
sign = ySum.BIT15 ' Store sign of ySum
ySum = ABS(ySum) ' Take absolute value
y = ySum / 10 ' y = the average measurement
IF ySum // 10 >=5 THEN y = y + 1 ' Fraction > .5? Round up
IF sign = Negative THEN y = - y ' if ySum negative, negate y
RETURN
If I run this second code, my robot start turning ccw and it dosen't stop.
How should I make my robot to turn 90 degrees cv or ccv?
DO ' Main loop
PAUSE 150
FOR counter = 1 to 33
PULSOUT 13, 780
PULSOUT 12, 780
PAUSE 20
NEXT
LOPP
How should I intorduce my angles in the last part of code?
How should I proceed if I want my robot to turn with 90 degrees in one direction or another?
Please help me, this would be my last problem
Andrei said...
I haven't done this but I would start by checking the angle right before turning. Then inside your FOR.. Next loop insert some code that checks the angle and if it is angle + 90 or angle - 90 then exit the loop. That would be a simple way to do it and maybe a good beginning.
To make a better code I would work the difference between the angle you want and the angle you are at into the the length of the pulse that you are sending to the servos.
- Stephen
' {$STAMP BS2}
' {$PBASIC 2.5}
qtis VAR Nib
counter VAR Word
OUTB = %1111
DO
GOSUB check_qtis
SELECT qtis
CASE %1000
PULSOUT 13, 670
PULSOUT 12, 670
CASE %1100
PULSOUT 13, 750
PULSOUT 12, 670
CASE %0100
PULSOUT 13, 790
PULSOUT 12, 670
CASE %0110
PULSOUT 13, 800
PULSOUT 12, 700
CASE %0010
PULSOUT 13, 830
PULSOUT 12, 710
CASE %0011
PULSOUT 13, 830
PULSOUT 12, 750
CASE %0001
PULSOUT 13, 830
PULSOUT 12, 830
CASE %0111
PULSOUT 13, 780
PULSOUT 12, 780
PAUSE 20
NEXT
PAUSE 20
NEXT
PAUSE 20
NEXT
PAUSE 20
NEXT
PAUSE 20
NEXT
PULSOUT 13, 720
PULSOUT 12, 720
PAUSE 20
NEXT
PAUSE 20
NEXT
CASE %1110
PULSOUT 13, 720
PULSOUT 12, 720
PAUSE 20
NEXT
PAUSE 20
NEXT
PAUSE 20
NEXT
PAUSE 20
NEXT
PAUSE 20
NEXT
PULSOUT 13, 780
PULSOUT 12, 780
PAUSE 20
NEXT
PAUSE 20
NEXT
CASE ELSE
PAUSE 3
ENDSELECT
LOOP
check_qtis:
DIRB = %1111
PAUSE 0 ' 0 -- suprafata alba
DIRB = %0000 ' 1 -- suprafata neagra
PAUSE 0
qtis = INB
RETURN
' {$STAMP BS2}
' {$PBASIC 2.5}
DO ' Main loop
ySum = 0
NEXT
RETURN
Please help to finish my license project.
Thank you very much.
Without seeing how you combined the two programs, it isn't
possible to find the problem.
Including the actual Stamp program as an attachment is always
a good idea.
phil
Rich H
assignments the same for the robot and the compass. His change will fix it.
phil
Thank you again.
DO ' Main loop
PAUSE 150
PULSOUT 13, 780
PULSOUT 12, 780
PAUSE 20
NEXT
LOPP
Thank you
Something like
Not presented as a solution, just a place to start.
Also, posting the same question in multiple threads is generally discouraged.
Rich H
Post Edited (W9GFO) : 6/14/2009 9:54:42 PM GMT
