More efficient serial
HI All
So i wrote a peice of SX code at work.
My project works, but i am using like 95%+ of the space on the SX28. Which leaves little room for future expansion.
So two questions.
Is there a hardware solution to get more program and or data space?
second
Most of my program involves sending and receiving strings.
I cannot post the real program, but below is the gist of what i have done.
Can i make this more efficient?
(Note that the send and receives may be at different baud·and pin settings, thus why i made 4 sub functions.)
Thanks a bunch
DEVICE SX28, OSCHS2, TURBO, STACKX, OPTIONX
FREQ 50_000_000
'DEVICE SX28, OSC4MHZ, TURBO, STACKX, OPTIONX
'DEVICE SX28, OSCHS2, TURBO, STACKX, OPTIONX
'FREQ 4_000_000
ID "Something"
PROGRAM Start
TX_COMMAND_BYTE SUB 1
RX_COMMAND_BYTE SUB 0
TX_DATA_BYTE SUB 1
RX_DATA_BYTE SUB 0
Start:
Main:
FOR idx = 0 TO 26
read monitor_log+idx,send_byte
TX_COMMAND_BYTE send_byte
NEXT
FOR idx = 0 TO 7
TX_DATA_BYTE up_or_down(idx)
NEXT
for idx=0 TO 7
if constant_log = 0 then
something_1(idx) = RX_DATA_BYTE
else
something_1(idx) = RX_COMMAND_BYTE
endif
next
GOTO Main
SUB TX_COMMAND_BYTE
SEROUT tx_commands, COMMAND_BAUD_RATE, __PARAM1 ' send the character
ENDSUB
SUB TX_DATA_BYTE
SEROUT tx_data, DATA_BAUD_RATE, __PARAM1 ' send the character
ENDSUB
SUB RX_COMMAND_BYTE
SERIN rx_monitor_pin, COMMAND_BAUD_RATE, subroutine_temp1,100,No_Data ' wait for serial input
RETURN subroutine_temp1 ' return to caller
ENDSUB
SUB RX_DATA_BYTE
SERIN rx_data_pin, DATA_BAUD_RATE, subroutine_temp1,100,No_Data ' wait for serial input
ENDSUB
monitor_log:
DATA "Something i cannot put here",13
Post Edited (lboucher) : 6/13/2009 2:49:11 AM GMT
So two questions.
second
Thanks a bunch
FREQ 50_000_000
'FREQ 4_000_000
ID "Something"
PROGRAM Start
TX_DATA_BYTE SUB 1
RX_DATA_BYTE SUB 0
Start:
Main:
FOR idx = 0 TO 26
NEXT
FOR idx = 0 TO 7
NEXT
for idx=0 TO 7
else
endif
next
GOTO Main
SUB TX_COMMAND_BYTE
ENDSUB
SUB TX_DATA_BYTE
ENDSUB
SUB RX_COMMAND_BYTE
ENDSUB
SUB RX_DATA_BYTE
ENDSUB
monitor_log:
It's hard for volunteers to help when details of what you are trying to do are not available, and no comments in the code. I'm a person who likes a challenge, but I expect the other party to do the work..... I try to give pointers so that they can learn.
As far as filling up your program space..... without studying your code, and based on my experience, I would estimate what you are attempting to consume 256 bytes if written tightly in assembler, and 2 times that in SX/B.
So look at the SX/B output listings, and see where all the space has gone, and make improvements accordingly.
Cheers,
Peter (pjv)
Sorry for the lack of comments, thought the code was generally self explanitory.
Just trying to send and receive various length sequences of various characters.
Really just wondering if there is a way to get rid of all the for loops, and make a biggers subfuction that handles the for loop.
Lucas
now that i drove home, sorry i wasn't completely clear.
So let me try again
Given this part of the main program
FOR idx = 0 TO 7
TX_DATA_BYTE monitor_log(idx)
NEXT
How do i move the FOR loop inside the sub function??????
SUB TX_DATA_BYTE
ENDSUB
And i am sending the data contained in the string monitor_log:
monitor_log:
And i cannot put the reference to monitor_log into the sub function because there would be several different strings stored in data. (Maybe i can get around this by simply an index, since i know all the different strings ahead of time, i just have to be careful not to repeat the serout functions. Hummmm.)
Any help greatly appreciated.
Lucas
Define the sub function with two variables.
1 being string length
1 being string reference number
so
TX_DATA_BYTE 1 7 (where 1 is string reference, and 7 is length.
then the sub funtion
SUB TX_DATA_BYTE
for idx = 0 to __PARAM2
if __PARAM1 = 1 then
send_byte=monitor_log(idx)
endif
if __PARAM1 = 2 then
send_byte=some_other_string(idx)
endif
SEROUT tx_data, DATA_BAUD_RATE, send_byte ' send the character
next
ENDSUB
Maybe if i assume the data is stored together i can simplify this more.
Meaning
if i have two strings
string_1:
DATA "STRING_1"
string_2:
DATA "STRING_2"
then, i think
string_1(9) = "S"
then i can get rid of the if in the sub function
i just have to pass a the start location and number of charaters to the sub function instead of an index and number of characters.
Heck i quess i should just store all the strings in one long data entry.
Cool
Tx_String sub 2 'declaration Tx_String @string_1 'usage Tx_String @string_2 Tx_String: 'writes strings terminated with 0 Addr= __Wparam12 'Addr is a word value do READ Addr,char IF char=0 THEN EXIT inc Addr serout tx,baud,char loop RETURN string_1: DATA "STRING_1",0 string_2: DATA "STRING_2",0Jeff T.
You say you're using 95% of the EEPROM space, and that your app mainly involves involves sending and receiving strings. So. my question to you is how much of the EEPROM space is used to store strings currently? In other words, if you're using 80% of the EEPROM space just to store strings, then what you need to do is either shrink the size of your strings or move them to an external serial EEPROM.
PeterM
I have managed to shrink everything down to about 80% of the EEPROM. I don't have the code in front of me, but no more than 10-15% was stored strings. Most of the program was receiving strings and parsing data correctly. I have never added EEPROM before. If i get to that point i will have to give it a try.
Lucas
