Regulator wiring, in-line or not
So I saw on one of the Parallax-fab propeller board (don't remember with one -- one of the big proto boards) that they had the 3.3V regulator supplied by the 5V regulator (Vin -> 5V -> 3.3V). I've always wired up my boards so the 3.3V and 5V regulators are supplied directly by the input voltage (Vin -> 5V, Vin -> 3.3).
What is the benefit of supplying feeding the 3.3V via the 5V.
In a project I am working on, the 5V circuit uses over twice as much as the 3.3V, so the regulator is already nice and toasty, putting the 3.3V load on there as well will only make things worse. I understand that the 3.3V regulator will need to dissipate less heat.
Is it just a matter of preference or is there some other thing I am overlooking?
April, 2008: when I discovered the answers to all my micro-computational-botherations!
propmod_us and propmod_1x1 are now in stock. Only $30. PCB available for $5
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
