how generate two frequency a quadrature in propeller
i download FrequencySynth from object exchange
but· i traying to generate two frequency from 0 to 125mhz
in quadrature 90 grades.
any ideas?
thanks a lot
any ideas?
thanks a lot
I need a square frequency , i try to make tayloe·mixer,·so square signal ok.
My target is to design a shortwave receiver with propeller
some info of tayloe mixer
http://www.oe1ira.at/sl/mix.html
thanks a lot
The problem is that the cog counters can produce a pulse train at frequencies up to around 160MHz with true and complement outputs. To get phase angles of 90 degrees, you have to divide the interval into four pieces which would limit the frequency to 30-40MHz.
Keep in mind that there's a PLL involved in the frequency generation and there's some jitter in the output, particularly as you get away from multiples of the crystal frequency. I wouldn't recommend it without a lot of cleanup.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
the articles that flow from a search on those mixers instantly took me back to the late 70s. VHF Comms were full of ccts that were lovingly constucted in milled out solids, only to be built by me in a mustard tin. Bloody things seldom worked.
