ZzzzzzzzzzzzzzzzzzzzAP!!!
We've all had a go of those toys that give you an electric zap when you aren't fast enough to push the button or what not. Anyone here know of a good way to build something like that? Safe, but shocking? Like the toys. Preferably with two settings. One for wimp and one for tough guy?
Who are you, and why are you reading my signature?
Some toys use a springloaded hammer to hit a crystal
Vandegraph generators can give you a safe 10kV but are physically large.
High frequency squarewave through a 1000:1 transformer is pretty safe if using 5v input
propmod_us and propmod_1x1 are now in stock. Only $30. PCB available for $5
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
My nephew used old worn-out cigarette lighters (no flint) to make a shock box.
Next time I see him I'll get it out of his head and on paper for you.
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
A solinoid could do the same but yourbest bet use a transistor to drive a hand wound transformer.
I have schematics for painfield generators and other stuff. Will post some Tuesday.
Thanks, mctrivia. I'll keep an eye out on Tuesday!
For something quick and dirty, setup a relay as an oscillator without a back-emf diode across the coil.
A little bit of trial and error and you'll know where not to touch.
If you want something that's more solid state, you can check out my patent ... US 6,500,210 ... with a schematic on page #5
The patent is more for the prosthetic application more than the actual circuit. The basic idea is pretty simple... you charge a capacitor, in this case through a 100 Ohm resistor. The NPN transistor is part of the auto-turn on circuit and can be omitted. The 470 Ohm and the 100 Ohm resistor form a voltage divider to the gate of an SCR. When the capacitor reaches a certain voltage determined by the voltage divider and turn-on threshold voltage level of the SCR, the SCR turns on rapidly dumping the capacitor charge into the primary coil of a small transformer. When the capacitor discharges, the SCR resets, and the process happens all over again.
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 6/12/2009 7:28:56 AM GMT
I was about to suggest precisely that until I scrolled down to your post. We ruined a fair few relays as kids using the kick of the back emf as a shock buzzer. Ahh.. kids don't have good clean fun like that anymore. Anything fun is illegal.
Eccles : How do I open the door?
Bluebottle : You turn the knob on your side
Eccles : I haven't got a knob on my side!
A little bit of trial and error and you'll know where not to touch???
I just can't picture this I took a 12 volt relay and tried putting an oscillating output to where the relay coil connects to energize the relay but nothing???? it only made the relay buzz?
Just look at the court cases coming out of the "harmless" use of conductive energy devices in law enforcement and the numerous folks who are now dead after its harmless application.
Tom Sisk
http://www.siskconsult.com
Beau Schwabe
IC Layout Engineer
You need to ensure as close as you can that it will be impossible for the charge to travel through the brain or heart. An otherwise healthy person
can receive a fairly mild charge (something around a static shock) and have heart problems as a result.
The biggest risk for toys like that is someone touching the contacts with one on hand each. This forces the current to travel a path through the heart.
Make sure your physical design of the contacts discourages this (make them extremely close together and hard to get to).
1 do not sell yourself. Incorporate or have someone else buy rights
2 have warning labels galore.
3 make sure it is impossible to get 507ma or more through heart
Please, I need less people repeating the same safety cautions and more people answering the originally posed question if possible. I appreciate the warnings, but I wouldn't be doing this without having done my research into the effects of electricity on the body. All I need is a little static zap.
Vandigraph generator is gauanted safe and easy to build but not small.
Some of those toys out there are pretty small though. I've seen laser tag systems that give you a shock if you get shot that fit inside a pistol...
Even if not for this very fun
