16x1 LCD Code...
I need some code for a 16x1 LCD....· It's the AC161B module.· I got the datasheet, and it just confused me even more...· How would I go about displaying some characters on the LCD?
EDIT--·I have attached the datasheet...· Can someone make sense of it and post a bit of code...?
Thanks.
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
Post Edited (Vaati) : 6/10/2009 10:19:26 PM GMT
Thanks.
there is some code for the basic stamp but it only works in 4 bit mode from what I can see here you are going to need all 8 data bits
Rayman is the resident expert on displays maybe he will jump in or you can ask him
Vaati I have included a drawing that show one of way of getting the bias voltage you might not have to use a negative voltage after all it not clear to me it looks like on your data sheet it was offered as an option.
Post Edited (mikediv) : 6/11/2009 4:05:27 PM GMT
