Two BS1 hooked up in parallel (quick question) — Parallax Forums
ashorashor Posts: 2
edited 2009-06-10 21:47 in BASIC Stamp
Hello all:
I have a program that is too large to run in one Basic Stamp1. However, there are really two parts to the program and they don't have to be on the same Stamp. Question: can I have two Stamps hooked up to the same I/O cables, and same ground cable. Then just power up whichever Stamp is required for each program? I would only power up one at a time.
The real question is: if a Stamp is not powered up, are the I/O pins grounded? Would the Stamp that is not powered up mess up the other's I/O pins?
Thanks very much for your thoughts!
Andy
    edited 2009-06-10 14:43
    Yes, the unpowered Stamp will drag down the powered I/O pins
  • ashorashor Posts: 2
    edited 2009-06-10 15:16
    Thanks Mike, I guess I have to slim down my program.
    Thanks for the help.
    Andy
    ashor,
    The Stamp without power will end up being powered through the ESD protection diodes inside the BS1. If you do this make sure that the BS1 program forces it's pins to be INPUTS
    Beau Schwabe
    IC Layout Engineer
