Info needed on switching
I am working on a project that will light up some LEDs.· If I hit the switch one through eight times , it will cycle through different patterns then come back to pattern one.·The switch is hard wired. It has one side to ground and a 1k ohm Resistor hooked to the other side to the input of the controller chip. What I intend to do is instead of hitting the switch to change the pattern by hitting it more than once, I would like to hook it to the basic stamp and just pull it to ground for the number of times until I get the desired effect.· I also plan to take the "switch" out of the circuit completely and select individual patterns instead of using them cycling through.· An example would be, I would like to use 3 then 5 then 1 then 2, etc. Instead of 1,2,3,4,5,6,7,8 all in a cycle. Hope I am making myself clear.· I was wondering if 1k ohm is enough of an isolation to the stamp.
Thanks in advance for your information.
Do you mean to hold it?
hope I was clear enough.
What do you think, Mike?
