loading DAT data from SD? — Parallax Forums
edited 2009-06-10 22:17 in Propeller 1
Before I start creating the wheel:
Has anyone done an example of loading DAT date from a file from the SD?
Is this even possible?
OBC
New to the Propeller?
  • RaymanRayman Posts: 16,460
    edited 2009-06-10 00:40
    OBC: I'm not sure what you mean...
  • BTXBTX Posts: 674
    edited 2009-06-10 01:19
    That's exactly what I'm thinking.
    I supposse OBC mean, take data out of a SD, to ie draw a bitmap in a driver, using that read data instead this:
    Hbar  long
            file "hbar.dat"     '4x1=4
    If I could read the hbar.dat from SD, could be great to save in it, a lot of graphics.
    Regards.
    Alberto.
    edited 2009-06-10 01:28
    I'm actually going one better...
    Since there seems to be a lot of shrugged shoulders, I'm knee-deep in spin.
    I'm writing an IPCONFIG program for my remote compiler which will allow me
    to change the TCP/IP address data and store it in a file called "ipconfig.cfg"
    My initial tests seem to indicate that I can load this data, then assign the
    variables into the DAT section. (We'll see)
    I've got most of the initial user interface finished, I'll be testing the concept shortly.
    OBC
  • CassLanCassLan Posts: 586
    edited 2009-06-10 01:35
    It shouldn't be a problem at all, I have done that.
    The program just needs the correct amount of DAT space allocated, you can replace the variables anyway you like.
  • CounterRotatingPropsCounterRotatingProps Posts: 1,132
    edited 2009-06-10 01:42
    Are you guys just swapping out the underlying data *physically* while the code vars are still the same, e.g. pointing to the same place = like a shared memory swap?
    - Howard
    No matter how much you push the envelope, it'll still be stationery.
    edited 2009-06-10 01:48
    Hmm the only thing that I can think of that is pesky is converting 1 then 9 then 2 .. into 192..
    You could setup a loop to repeat the same number of times for each place value;
    readbyte HUNDREDSCOLUMN from SD
    repeat HUNDREDSCOLUMN
         Octet := Octet + 100
    readbyte TENSCOLUMN from SD
    repeat TENSCOLUMN
         Octet := Octet+10
    readbyte ONESCOLUMN from SD
    repeat ONESCOLUMN
         Octet := Octet +1
    Although I'm not familiar with the driver or how the IP info needs to be presented...I've got to fool around with that PropNIC that arrived last week!
    Rick
    edited 2009-06-10 02:02
    Nah,
    That was the easy part. I simply wrote one character for each number of the
    address, etc. I only needed numbers 0 - 255.
    I'm now dealing with the other side. As feared my DAT statements don't like
    accepting variables. (Still poking at it.)
    OBC
    edited 2009-06-10 02:28
    why not just overwrite the variables in hub ??? or am I missing something?
    · Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
    · Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
    · Search the Propeller forums (via Google)
    edited 2009-06-10 02:46
    Never tried it before.. Never needed to.. [noparse]:)[/noparse]
    Yes, I have it working fine.. Too bad you guys won't see it until UPEW. [noparse]:)[/noparse]
    OBC
    edited 2009-06-10 11:16
    Can't wait!
    And you can edit the ipconfig.cfg with a text editor?....like PrEditor?roll.gif
    See you then!
    Rick
    edited 2009-06-10 12:27
    CassLan said...
    Because each digit of the configuration file represents part of the TCP stack
    configuration I wrote a special configuration screen for it.
    BTW, how is your editor coming along? It's been a while since
    we've had an update.
    OBC
    OBC said...
    Sweet, looking forward to seeing it.
    Yeah, work got very busy...Just installed my first Prop based product this week!
    I will have PrEditor done for the expo though.
    Rick
