MCP2510 Clock Out -> Prop Clock In
So I'm going to be using a MCP2510 CAN bus controller ... mostly because I want a really solid bus and don't want to hassle with writing a S/W implementation right now.
The chip has a clockout with a software controlled divider and its active immediately after reset...
So I'm a little short on board space and was thinking of using this to clock the propeller, but I've never tried this sort of thing before and wanted to know if anyone else has had success with something similar.
As long as it works, the only negative I can see is that resetting the MCP2510 from the prop would result in the prop's clock changing...maybe even glitching out for a while.
I don't know how important resetting the chip might be...I usually connect reset pins to spare I/Os just in case it becomes useful, but sometimes I don't ever end up using them.
heres a link to the datasheet: ww1.microchip.com/downloads/en/DeviceDoc/21291F.pdf
Any words of wisdom?
When your program initializes itself, it needs to start with the built-in clock first in case the MCP2510 was just reset.
Crystals are cheap and don't take much board space.· It would be much simpler to use a separate clock for each or even use the Propeller's clock for the MCP2510.
the more I think about it...you're right. The prop's crystal just isn't expensive enough to be worth the hassle.
I might consider clocking the MCP2510 from the propeller though since that would be a lot simpler
Is there any real difference between the propeller outputting a 20Mhz clock signal and the MCP2510 having its own 20Mhz crystal?
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
