Wireless Programming
Has anybody had luck programming the prop over wireless. It looks like the XBEE modules have tx rx and dtr for the reset so they could simply swap out for the USB programmer. I was just wondering if lag caused a problems while programming.
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 6/9/2009 1:58:33 AM GMT
Basically it uses 2 proto boards and runs a pair of cogs on each end. On the PC end one cog pretends to be a bootloader on different pins and receives the program from the Prop Tool storing it in the on-board ram. It then flags the other cog to start sending it to the other end.
The transmission consists of 64 byte packets that are coded using a horrible home-cooked encoding based on differential-manchester with a 16 bit CRC. Each one is sent and acked when it hits the other end. I used the nasty hacks I did as the receiver can auto-sync to the bitrate of the transmitter from 115,200 bps to about 300bps with no accurate clock and no prior knowledge of the inbound rate required. This is so the transmitter and receiver can both be running off RC oscillators and still communicate reliably. The RF cog is self contained, with 64 byte buffer, CRC checking/generation and all RF code built in. This removes the requirement to use HUB ram while communicating.
The Cogs talk to each other using the last long of RAM (as no normal program image is ever going to put something there)
On transmission of the final packet, it signals the other end that things are complete and to load the prop.
The remote end receives the packets and builds a 32K image in its ram. When the image is complete it signals the second cog to reset and load the target propeller.
I have about 2/3 of it working (The PC end and the data transmission) but I've been working on it on and off for 4 months now and never really got around to finishing it off.
The big downside is it's very slow. The upside is it can be done with a prop plug, 2 proto boards and 2 RFM12B modules and is relatively cheap.
The comms is bulletproof as its all packetised and CRC checked.
I can get an effective rate of 115,200 baud if the boards are less than about 30cm apart. That drops to 2400-4800 if they are in the next room and about 1200 if it's out in the garage.
Even at 115,200 it takes a good minute to reliably transfer a full ram image across. I've never benchmarked it at 1200 as it's far quicker to walk out there with my laptop, plug it in and download the image.
I'll finish it off one day, but you can't rush these things.
I've taken to using 6 core 7/0.20 security cable between the prop plug and the target board. If I ground 3 wires and use the other 3 for signalling I can usually get about 20M between the PC and the target. If I need more I use 2x3M USB extenders between the prop plug and the PC.
"VOOM"?!? Mate, this bird wouldn't "voom" if you put four million volts through it! 'E's bleedin' demised!
Leon
Basically, I had a gumstix with WiFi and used socat to forward a TCP port to the gumstix's serial port which was connected to the propeller.
I could then send hex files to the propeller which it would load into RAM or directly onto the EEPROM and reboot.
The bootloader was part of the debug/comm driver cog between the gumstix and propeller.
I never did it with just an XBEE, but it certainly should work, the delay and lag isn't a problem because its using a real UART not chip's magical version that auto-syncs (which was brilliant, but in cases like this a real pain)
Unfortunately, I don't think Chip ever implemented my "auto-save-a-binary-copy-every-time-you-compile" feature, so you have to manually save the binary output... A file watching script can easily initiate the download process after that.
As general purpose serial bootloader and com port ... its pretty useful. I think I need to update the interface to be compatible with the Parallax Serial Terminal since that didn't exist back when I wrote it.
It also allows arbitrary manipulation of the propeller's RAM remotely and a some data logging features...nothing close to what you can do with viewport though.
Actually I really like the work hanno did wit h the viewport tool. I've had good success using that over wireless, but I don't think he ever put a bootloader into his protocol.
There is so little data to send maybe you could use an LED as a photodetector and just write your own
bootloader code and transmission protocol and just 'blink' the data over
upgrades of a product by users.
There are many possibilities for sending the blinking data using a PC or some dedicated device.
This is a rather silly way to do this but I'm always looking for the cheapest way to do anything and if
your device already has an LED somewhere on its case this might cost nothing at all.
of the project under wraps until after UPEW.
I'll give the hint that it is based on the Remote Compiler project.
OBC
New to the Propeller?
See: "Kermit EEPROM Console" in the Protocols section of the Propeller Object Exchange.
Eric
What It Looked Like to the User
Not all of the transmission was visible to the user. The most noticeable part of the transmission was the report of status codes like ACK, GOO, BAD, and SYN for handshaking results. A typical transmission might look like ACKGOOGOOGOOGOOBADGOOGOOGOOBADGOO, with bad blocks reported to the user just as frequently as they occurred. This allowed users to record the error rate according to hour and day of the week, and determine which hours of the day, and which days of the week had cleaner phone lines. Unlike modern PC computers, the C-64 and C-128 could poll the User Port (where the modem was interfaced) at slightly different BAUD rates and connection speeds. For instance, a transmission at 1200 BAUD on Sunday evening might actually produce fewer errors than 2400 BAUD on Tuesday afternoon. By choosing slower BAUD rates, files could actually be transmitted faster than at higher BAUD rates, inasmuch as there were fewer re-sends in a given transfer.
http://en.wikipedia.org/wiki/Punter_(protocol)
http://cbmfiles.com/genie/geniefiles/TelcomTools/C1-PROTOCOL-DESCRIPTION
···· John: Put part "A" in hole "D".
···· Ken:· Understood, putting part "A" in hole "D".
···· John: Acknowledged, let me kow when you are ready for the
·········· next instruction.
···· Ken:· Go ahed, what do· do next?
···· John: Put screw "E" through slot "T".
···· Ken:· I didn't undertand that, could you please repeat.
···· John: Oh ok, tell me when you're ready for that instruction
····················· again.
