Propeller materials as a gift...what to include?
Hey Folks,
OK so I have a good buddy of mine who now lives in FL (we grew up together in Brooklyn, NY). He's turning 30 and his wife is throwing a party for him.
We don't see each other that much these days, and since I'm going to FL for his party I wanted to give him the gift that keeps on giving..the Propeller!!!
He's always interested in my little electronics projects..making joysticks..modding consoles..etc
He is in the IT field and has great knowledge of networks/programming.
He has no experience however with microcontrollers or electronics for that matter.
I don't have a tremendous budget but I wanted to put together a few things together that can get him started with the propeller, I'm sure he will love it.
I would like to get him stuff that can get him going immediately and also an opportunity to make his own designs down the road.
Again, he has nothing as far as electronics tools/test equipment.
Here is what I was thinking:
Propeller Proto Board
9V Powersupply
Propeller Proto Board Accessory Kit
PropPlug
Multi-Meter
Soldering Iron
Printed Copy of "The Propeller Cookbook"
Resistors for NTSC Video
An RCA Cable
Some LEDs
BreadBoard
Prop DIP
5Mhz Crystal
Jumper Wires
Bread Board PS2 Jack
Bread Board RCA Jack
Some Header Pins
3.3V & 5V Regulator
I wanted to get the forums opinion..am I leaving anything out?
Rick
9V Powersupply
PropPlug
Multi-Meter
Soldering Iron
An RCA Cable
Some LEDs
BreadBoard
Prop DIP
5Mhz Crystal
Jumper Wires
Some Header Pins
3.3V & 5V Regulator
Rick
copy of free version of eagle with the prop package available from cadsoft.de
may want to consider spinstudio over prop protoboard as it lets pluging modules in without soldering or a propmod-us as it lets you run everything off a solderless bread board.
propmod_us and propmod_1x1 are now in stock. Only $30. PCB available for $5
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
grab a USB·memory stick and load it for him will all the prop tools you can think of, include docs, and some links to helpful videos - prop stuff of course, how to solder, etc.
As a programmer, who's venturing back into hardware myself, I've found the most useful things to be simple code samples that can make something work right away... the tools have this already, but you might want to mention that ... "hello world" in Spin and Asm does wonders.
If he's a networking guy, make sure you include some links to the RS232, RS485, USB, and Networking kits, addons, and other sites that have this stuff - he might get a real kick out of having his propeller gift controllable from his web site [noparse]:)[/noparse]
HTH
- Howard (in Florida too [noparse]:)[/noparse]
No matter how much you push the envelope, it'll still be stationery.
Rich H
Toys are microcontroled.
Robots are microcontroled.
I am microcontroled.
Maybe program a coupla EEPROMS with some fun stuff he can build up on that breadboard.
Edit: If possible, get a HYBRID board from Coley. It's a great board and the IDE connector exposes a lot of I/Os for use with the breadboard. I do this and I've seen others do it. (baggars) Of all the boards I've run, that one is just rock solid and works great.
It's really nice to have a fully built up system, SD card, etc... Build up code on the working unit, run games, etc... for some instant gratification, then build out a project with the other goodies you have planned.
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
Safety Tip: Life is as good as YOU think it is!
Post Edited (potatohead) : 6/7/2009 10:25:08 PM GMT
Rich H
- Howard
( Have Propeller and SX, Will Travel )
I'm going to look more into that.
WOW...the SpinStudio Mainboard + Game Stacker pretty much has everything to get your feet wet instantly.
Pretty economical also.
I'll probably go with that + a propplug and psu and lots of examples all setup as suggested.
Then if he wants to take it further he can.
I appreciate everyones input.
Rick
Post Edited (CassLan) : 6/7/2009 11:29:25 PM GMT
Rich H
I agree
Disclaimer: I cannot guarantee any information i post is accurate, but most of the time, it is correct.
Misses 8 bit computing
You may also want to consider the ybox2. It's a networking type module...
