BS2sx substitution for BS2 and the HB25
Hello...I have found it necessary to substitute a BS2sx for the BS2·in my application do to not enough EEPROM room on the BS2.· I have no problem using multiple programing slots to have/get more EEPROM program space.·
Having said that, I am using a couple of HB25's, configured to run in parallel from the same PULSOUT pin.· In reading the documentation data, it mentions that BS2sx users will have to pay more attention to the PAUSE command for the "time out pulses"· With the BS2, PAUSE 1 and PAUSE 5 is used.· Any recommendations on what PAUSE duration to use for the BS2sx when controlling two HB25's?
Deno
Deno
Take a look at PAUSE pg.311 Syntax reference Manual. What I get out of this is the STAMP directive will do the math from one stamp to another. Meaning PAUSE 1 will = 1 millisecond on any stamp. Timing with CON values is a hole different story.
___________$WMc%____
The Truth is out there············································ BoogerWoods, FL. USA
DenO
