BoeBot on MSRS via Serial Port
I am getting frustrated waiting on an answer to this from MS so I am looking for a bit of help here. I need to know if it is possible to connect·MS Robotics Studio 2008 Express edition to my Boe Bot via a serial port as opposed to using a Bluetooth module and if so, how do I go about doing it? Is there a way to modify the Parallax file to just use a Serial Port and not BT? I do not want to go to the expense of buying a module that I will not be using. I have an ITX board connected to my network wirelessly and will use VNC to connect to and run the robot. (I hope)!!!! Thanks if you can giving me any guidance to this problem.
- Stephen
- Stephen
- Stephen
