Help Programming a Heel Strike/Toe Lift Pressure Switch
Hey everyone,
Excuse me for any newbness I may exude - I am a beginner and have very little experience.
I am programing a BoE-USB to work with a Heel Strike / Toe Lift lift pressure switch. The heel switch and toe switch are two separate switches, with the heel switch going to P6 and the toe switch going to P7. When pressure is put on the heel, the heel switch closes, and when pressure is put on the toe, the toe switch closes. I am currently able to measure the amount of time elapsed when a person's heel strikes the ground to when that person's toe lifts off the ground. However, I need to be able to measure at what time each step is taken. For example, step 1 was taken after 3000ms of time was elapsed, step 2 was taken after 5000ms of time was elapsed... step 300 was taken after 355000ms of time was elapsed... and so on. I do not know how to code this. In addition, I need to be able to record this data on a flash drive using a Memory Stick Datalogger (IC: 27937). For that, I am using some example code provided on the Parallax website and have hooked it up using the quickstart guide. My code is as follows:
Also, if possible, I want to measure the amount of time elapsed when a persons toe lifts off the ground to when that persons heel returns to the ground. I don't know if this is possible, though, due to the necessity to record the data and the amount of "lag time" recording the data takes. The measurements need to be as accurate as possible.
Any help in this is much appreciated.
Thank you in advance!
' {$STAMP BS2}
' {$PBASIC 2.5}
' -----[noparse][[/noparse] I/O Definitions ]-------------------------------------------------
TX PIN 8 ' Transmit Data --> 27937.4 (RXD)
RTS PIN 9 ' Request To Send --> 27937.6 (CTS)
RX PIN 10 ' Receive Data <-- 27937.5 (TXD)
CTS PIN 11 ' Clear To Send <-- 27937.2 (RTS)
' -----[noparse][[/noparse] Constants ]-------------------------------------------------------
Baud CON 84 ' Serial Baud Rate 9600 bps (BS2)
' -----[noparse][[/noparse] Variables ]-------------------------------------------------------
buffer VAR Byte(15) ' Input Buffer
index VAR Byte ' Index Variable
ioByte VAR Byte ' Input/Output Storage
work VAR Word ' Work Variable
flag VAR Bit ' Event Status Flag
timeCounterX VAR Word ' Heel Strike
timeCounterT VAR Word ' Toe Strike
stepCounter VAR Word
' -----[noparse][[/noparse] Initialization ]--------------------------------------------------
DEBUG CLS, "Heel / Toe Strike Transducer Program V0.2 Beta", CR, CR
PAUSE 3500
DEBUG "Initializing..."
PAUSE 200 ' Allow Time To Settle
HIGH TX ' Initialize Transmit Line
LOW RTS ' Take Vinculum Out Of Reset
PAUSE 600 ' Allow Time To Settle
DEBUG "Done!", CR, "Synchronizing..."
DO
SEROUT TX\CTS, Baud, [noparse][[/noparse]"E", CR] ' Sync Command Character
GOSUB Get_Data ' Get Response
PAUSE 250
LOOP UNTIL ioByte = $0D ' Wait For Carriage Return
DO
SEROUT TX\CTS, Baud, [noparse][[/noparse]"e", CR] ' Sync Command Character
PAUSE 250
' -----[noparse][[/noparse] Program Code ]----------------------------------------------------
Main:
DEBUG "Done", CR, "Switching to Short Command Mode..."
SEROUT TX\CTS, Baud, [noparse][[/noparse]"SCS", CR] ' Switch To Short Command Mode
GOSUB Get_Data ' Purge Receive Buffer
DEBUG "Done!", CR, "Waiting for Memory Stick..."
Check_Drive:
DO
SEROUT TX\CTS, Baud, [noparse][[/noparse]CR] ' Prompt Device For Status
IF buffer(0) = ">" THEN ' Check For Ready Prompt
EXIT ' If Ready Then Exit Loop
ELSEIF buffer(0) = "N" AND buffer(1) = "D" THEN
DEBUG "." ' Device Ready But No Memory Stick
ELSEIF buffer(0) = "D" AND buffer(1) = "D" AND flag = 0 THEN
DEBUG "Connected!", CR, "Accessing..."
flag = 1 ' Memory Stick Ready
ELSE
DEBUG "."
ENDIF
PAUSE 250 ' Command Retry Delay
LOOP
DEBUG "Ready!", CR
DEBUG "Opening Data File..." ' First Delete File
SEROUT TX\CTS, Baud, [noparse][[/noparse]$07, $20, "datafile.txt", CR]
' Then Create File
SEROUT TX\CTS, Baud, [noparse][[/noparse]$09, $20, "datafile.txt", CR]
DEBUG "Open!", CR, CR, "Writing Data File...", CR, CR
FOR stepCounter = 1 TO 10
DO
LOOP UNTIL IN6 = 1
timeCounterX = 0
timeCounterT = 0
DO
timeCounterX = timeCounterX + 1
LOOP UNTIL IN7 = 1
DO
timeCounterT = timeCounterT + 1
LOOP UNTIL IN7 = 0
DEBUG "Step # ", DEC stepCounter , CR, CR,
"Stance time = ", DEC timeCounterX + timeCounterT ,
" ms.", CR, CR
SEROUT TX\CTS, Baud, [noparse][[/noparse]$08, $20, $00, $00, $00, $0D, CR,
DEC stepCounter, ", ", DEC timeCounterX + timeCounterT , CR, LF, CR]
PAUSE 200 ' Write Results/Delay
NEXT
DEBUG CR, "Closing Data File...", CR, CR ' Close File (MUST CLOSE!)
SEROUT TX\CTS, Baud, [noparse][[/noparse]$0A, $20, "datafile.txt", CR]
' Open Fil For Read Mode
PAUSE 2000 ' Dramatic Pause
DEBUG "Data collection complete."
STOP
' -----[noparse][[/noparse] Subroutines ]-----------------------------------------------------
Get_Data:
index = 0 ' Reset Index Pointer
DO ' Receive Data
SERIN RX\RTS, Baud, 100, Timeout, [noparse][[/noparse]ioByte]
buffer(index) = ioByte ' Add Received Byte To Buffer
index = index + 1 ' Increment Index Pointer
IF index > 14 THEN Timeout ' Check For Overflow
LOOP
Timeout:
RETURN
- Stephen
Now if you just need seconds only
Here is a Second Counting Register Not reading the data from the DS1302 chip in BURST MODE
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 6/6/2009 9:38:58 PM GMT
Is it possible to display milliseconds using that code???
No· DS1302 is not capable of doing·milliseconds
You would need to use a different time chip
··Thanks for any·
Sam
Rich H
