Hot capacitor
I have a product w/a 24v power supply. In it there is a small circuit that gets regulated to 5v via a 7805.
It uses a 2 caps at the regulator a 1uF 50v(electrolytic) on the 24v side and a .1uF on the 5v side.
The 1uF is getting pretty warm - almost hot. This is the first one out of 10 or so I have put together that I noticed this with.
There is not much current flowing.
I am wondering if any of you guys can think of reasons for this happening. Is it possible for bad caps to do this?
BH
BH
propmod_us and propmod_1x1 are now in stock. Only $30. PCB available for $5
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
But 24V-5V = 19V at say 100ma (at least) = 1.9W that the 7805 has to dissipate which means it gets very hot. Anyway, the heat has to go somewhere, even with a heatsink, could the 1uF be next to it?
Hint: Linear regulators are not very suitable for high input/output differential supplies unless you are only drawing 10's of milliamps. Switching regulators are a solution though.
*Peter*
Sorry for the crappiness
*Peter*
I do agree about regulator in close proximity. I just thought of reverse first.
Jim
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
P.S. If you get a switch mode PSU that is dead, always try the small value ones on the HV side. They are always overheated/underated and dry out, if it isn't that then it probably has deeper problems that are worth the hassle of repairs.
Toys are microcontroled.
Robots are microcontroled.
I am microcontrolled.
Ripple current is one of the characteristics I see overlooked frequently. (sometimes it is even hard to find that rating for a given cap)
The cap is trying to do its job (I am assuming it is·intended to be a filter cap) and if the applied dc voltage has significant ripple then the cap is working overtime.
Usually the input side cap is the small value one, and the output side is the bigger one (which must have ESR within the reg's acceptance range). But then you say that all the other ones worked ok.
24V down to 5V is quite a drop, if you switch off all the lights does the reg have a "friendly glow"?
I checked the 7805 datasheet. His values are okay — but just barely.
Once the reversed component was righted everthing went back to normal.
Thanks for all the help. It's better than a capacitor chapter in a book.
Jim
I am microcontroled.
