Boe Bot and MSRS
OK, So I found the .bs2 file that I need to use to communicate with MS Robotics Studio. However, I am not using a Bluetooth device. Is there any way I can modify the attached code to run through Serial Port 8, rather than using the Bluetooth adapter? Thanks if you can help.
