Newbie Basic Question
Can someone provide a schematic,·including·pin·designations, & a·component list of a circuit that will take a BasicStamp output voltage and, (using inexpensive components,) turn on/off a standard household device?· ·The dumbed down the better. <|:-(
PS Will an OMI-SS-212D work·for this?·
Depends on the load, for controlling heaters and incandescent lights you ca go up to 5 amps. for motors or florescent lights/bulbs 1.5 amps max. Now since most outlets in you house will be 20 or 15 amp be sure to put a fuse in parallel with you load.
as a schematic do a google search for "stamp driving relays" or check out:
also **** Do not omit the protection diode****
Lincoln, what software creates the schematic you posted?
Dominic
Deus tantum me iudicabit
http://www.sparkfun.com/commerce/tutorial_info.php?tutorials_id=119
