Modifying Dat in program. — Parallax Forums
Clock LoopClock Loop Posts: 2,069
edited 2009-06-06 23:43 in Propeller 1
Can a dat entry, like such.
DAT
FourBytes                byte    $00, $FF, $00, $0F
Be modified in a running program?
Say I wanted to modify the first byte in FourBytes.
From value $00 to value $FF. How would I do this?
I tried looking at the prop manual, and didn't see anything there. I tried a forum search...
  • RaymanRayman Posts: 16,414
    edited 2009-06-05 12:47
    There are many ways to do it... One is:
    byte[noparse][[/noparse]@FourBytes]:=$FF
    You can also just do (since you just want the first byte):
    FourBytes:=$FF
    If you want to get at·the nth byte (n=0..3), you can do:
    FourBytes[noparse][[/noparse]n]:=$FF
    or,
    byte[noparse][[/noparse]@FourBytes][noparse][[/noparse]n]:=$FF
    or,
    byte[noparse][[/noparse]@FourBytes+n]:=$FF
    edited 2009-06-05 12:55
    So DAT is just a different way of declaring a variable?
    Meh. Nothing here, move along.
  • heaterheater Posts: 3,370
    edited 2009-06-05 13:10
    Yes and no.
    If you create many instances of an object in your program they will all have their own private VAR space in memory but they will all share the same DAT space.
    edited 2009-06-05 18:54
    I get it now.
    If I ran 2 copys of the same object(different names), their DAT statements would be accessable to eachother, but their variables stay local to that object?
    Thats why one doesn't need to be careful with variable names, but im assuming with DAT you must be careful with names because if two objects have a Dat with the same name problems happen?
  • BradCBradC Posts: 2,601
    edited 2009-06-05 23:55
    BPM said...
    I get it now.
    No all symbol names (DAT/VAR/PUB/PRI) are local to the object. There are no collisions between names across different objects.
    "VOOM"?!? Mate, this bird wouldn't "voom" if you put four million volts through it! 'E's bleedin' demised!
    edited 2009-06-06 21:53
    I have another question along the same lines.
    Lets say I launched an object to read a value and told it to store that value at the address of INFO.
    CON
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
    OBJ
      modinfo: "modinfo"
      serial : "fullDuplexSerialPlus"
    PUB start
    modinfo.start(@info)
    serial.start(03, 02, 0, 57600)
    serial.hex(info[noparse][[/noparse]0],2)
    serial.str(string(9)) 'TAB
    serial.hex(info,2)
    waitcnt(400_000 + cnt)  ' let serial finish printing before stopping.
    serial.stop
    DAT
    info                byte    $00, $FF
    Now the modinfo.spin code.
    CON
    PUB start (infopointer) | moreinfo
    moreinfo := $FF
    infopointer[noparse][[/noparse]0]:= moreinfo
    This part
    is not working.
    Or something.
    Because when i run the program, it still prints
    $00              $FF
    edited 2009-06-06 22:40
    You're passing an address via infopointer. So instead of
    use
    byte[noparse][[/noparse]infopointer] := moreinfo
    infopointer is just a local variable that receives the value @info. Changing a local variable by assigning to it has no effect outside the method to which it's local.
    Post Edited (Phil Pilgrim (PhiPi)) : 6/6/2009 10:45:15 PM GMT
    edited 2009-06-06 22:44
    so not only do I have to tell it where, I have to tell it how much info to pass?
    well what if I wanted to pass the n'th byte?
    byte[noparse][[/noparse]infopointer [noparse][[/noparse]n] ] := moreinfo    '?
    Well this doesn't work, ...
    I just read the prop manual on
    BYTE
    That answered my questions.
    Thank you all.
    byte[noparse][[/noparse]infopointer][noparse][[/noparse]n] := moreinfo
    ** P O O F **
    Post Edited (BPM) : 6/6/2009 11:17:48 PM GMT
  • mparkmpark Posts: 1,336
    That manual is just chock full of useful information.
