No Propeller Found on any serial Port!
Hi together,
i'm setting up a new Propeller-Board, but i've got trouble with connection the prop to my PC.
I connect it, my laptop finds the com-port, but when i hit F10 in my Propeller Tool, it calls "No Propeller found on...".
I'm pretty sure that it has something to do with my USB2Serial-Connector. I connected the RX/TX Pins, the GND pin, but i don't know what to connect with the RESn-PIN on the propeller side? Which Pin of the USB Mini-B FT232R Evaluation Module do i have to connect?
Thanks to you!
Thanks to you!
http://forums.parallax.com/forums/default.aspx?f=25&m=285927
Second post has your answer.
I didn't know myself, but knew it was here.
I did this by going to: http://search.parallax.com
and putting in these keywords: serial reset pin forum propeller
[noparse]:)[/noparse]
Meh. Nothing here, move along.
Your FTDI eval chip has no pin access. Unless you can get at the DTR pin and wire it to your reset pin on your propeller, you need to get a propplug, or a non-evaluation ftdi chip.
Basically you need more than TX and RX on your USB device. You need DTR also. OR RTS
Post Edited (BPM) : 6/5/2009 10:11:48 AM GMT
LOL, after looking at the propeller tool preferences.... you can use RTS as your reset.
Connect reset to the RTS pin on your usb device. Pin 3 i think.
The go into the propeller tools "Preferences" (F5) and choose the operation tab, and under "port management" choose propeller reset signal of RTS.
It should work. Make sure you set your usb device to 3.3v mode.
Post Edited (BPM) : 6/5/2009 10:19:25 AM GMT
That's what i measured:
Prop: Powered
USB: Disconnected
Measured: ca. 2,6V
Prop: Powered
USB: Connected
Measured: Voltage goes up on 3.3V then:
7 times down to 0V (1 short time, then 3x 2 short times)
then 3.3V
when trying to acces Propeller:
just 1 short time down to 0V
Questions:
1) Why is there 2.6V when not connected to PC?
2) Could that fact be a cause of my Problems?
3) When not, the whole resetting-thing doesn't seem to be my problem?! What other possibilities are there?
Thank you very much for your help!
propwell
Post Edited (propwell) : 6/5/2009 3:03:26 PM GMT
For any chip, get the datasheet, ...
You should always read in detail what each pin does,
and what you need to do to get it into its normal state.
The propeller for basic use, needs the BOEn-pin tied to GND.
That would have made it not work.
I should have asked before, can you post your schematic? draw it in mspaint or something.
Does that help.... ?
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
Then i changed something (what a petty: i don't knpw anymore WHAT) and i doesn't work now at all!
I'm becoming crazy...
Basic Stamp,···· Propeller,·· · SX,·· FUN!
START:·
>Proccessing Data. . . .··
>Task Complete. . .·.
>Saving Data. . . .
>Entering SLEEP Mode. . . .
>Signing OFF
