Connecting a dance(something, probably not mat) to the hydra. — Parallax Forums
GooL91GooL91 Posts: 7
edited 2009-06-12 15:56 in Propeller 1
Hi!
I've read more than half of the book and I still can't figure out how to get the HYDRA to compute simple I/O. All I want is for the screen to go full-black or full-white when I press any buttons.
File?id=dhcjw96g_2ggsb2thp_b
Now, I use 10 pins for connection.
1 for "power" and 9 for the buttons.
...When you step on one button the hydra recieves a "1" though one of the i/o hole on the experimenter-Card, then fill the screen with white, else show a blank screen.
Can somebody please provide me with some help?
  • ColeyColey Posts: 1,110
    edited 2009-06-05 20:26
    Hi GooL91
    when you say 'power' what do you mean?
    A schematic of how you have wired it up would help us to help you.
    I would pull each of the iputs up to 3v3 with a 10K resisitor and put the common pin to ground, so when you press each button the signal transition is from high (1) to low (0)
    Coley
    PropGFX - The home of the Hybrid Development System and PropGFX Lite
    edited 2009-06-05 23:47
    Good idea, this way it is easier for the prop to detect it. Oh.. and the Experimental Card only has 7 inputs(dosn't it??)
    Toys are microcontroled.
    Robots are microcontroled.
    I am microcontrolled.
    edited 2009-06-06 04:24
    Which system was the PAD designed for?
    OBC
    New to the Propeller?
  • GooL91GooL91 Posts: 7
    edited 2009-06-06 20:39
    To Coley:
    A schematic is probably not needed. I've already done the wiring like you said, thank you for confirming my greatness. scool.gif
    To MicroControlled:
    To OldBitCollector:
    It was a standalone system. It included a dance-game an a pinball one. I just tared it apart an put the cables in.
    ...Ten of them.
    edited 2009-06-06 21:55
    GooL91 said...
    Well how about posting some code then, it could be something simple, otherwise we'll have to start polishing our crystal balls tongue.gif
    Coley
    edited 2009-06-07 18:37
    Coley said...
    Coley
    Sorry for not being clear in the first post, I was tired.
    Here is a schematic:
    File?id=dhcjw96g_3fpv2vkhr_b
    Edit:
    Oops! I forgot to include the 3v3...
    Post Edited (GooL91) : 6/7/2009 8:10:42 PM GMT
    edited 2009-06-12 11:00
    ...How many pins can be used on the hydra for this? 'Cause I nedd 10 or 9.
  • Spork FrogSpork Frog Posts: 212
    edited 2009-06-12 13:38
    The Hydra expansion slot brings out 14 I/O lines from the Propeller, though really only 10 of those are usable because 2 are for the EEPROM and 2 are for the USB-Serial converter -- not a good idea to use those twice.
    I/O 0 through I/O 7 as well as the 2 HydraNet lines are free game -- 10, which seems enough for your application.
    edited 2009-06-12 14:03
    You could always grab a couple 4021N's from digikey.
    (These are the same used in the NES controllers) -- Heck for all that
    matters you could (GASP!) gut a couple old controllers and use the
    cables as well. Route all the I/O thru the game ports, using the
    available spin for game controllers.
    It would make your PAD compatible with a bunch of existing games
    at the same time. [noparse]:)[/noparse]
    [noparse][[/noparse]NES controllers really aren't that rare.. I bought three of them
    for $5.00 each (in perfect condition) from the local game trader.]
    OBC
    Why not try a NES Nintendo POWER PAD Accessory? It should already have the correct connector for the Hydra and just plug in. There are a few up on ebay right now. Item #'s: 260427323652 , 390058722851 , 190313913182 and probably others.
