Air Pressure Sensor for Kite — Parallax Forums
HumanoidoHumanoido Posts: 5,770
edited 2009-06-06 13:32 in Accessories
Using Parallax parts, is there a low cost simple way
to make digital air pressure sensors for flying on kites?
I don't recall anyone making a sensor for the Basic Stamp, or see
any links. If you know atmospheric air pressure, altitude can
be roughly determined, which is the objective.
humanoido
  • dredre Posts: 106
    edited 2009-06-05 16:05
    Would this link help?
    http://www.rocket-roar.com/rap/alt.html
    cheers, David
  • sylvie369sylvie369 Posts: 1,622
    edited 2009-06-05 16:55
    There are quite a few options for barometric pressure sensors with the appropriate range, but precision may be an issue. Here is a nice little $11 sensor that detects from 15 to 115 kPa (2.2 lbs/in sq to 16.7 lbs/in sq)
    http://www.freescale.com/files/sensors/doc/data_sheet/MPX4115A.pdf
    and a site that will give you a quick reference for how pressure corresponds to altitude:
    http://www.engineeringtoolbox.com/air-altitude-pressure-d_462.html
    It'd be nice to have one whose entire range covered just the lower altitudes, though the last time I flew an barometric altimeter it did go to 94,000 feet (in a balloon), which would have maxed out that 4115 sensor. We flew a Honeywell ASDX015A24R, which is a bit pricier ($32) but can measure right down to a nearly pure vacuum.
    Anyway, they put out a nice linear voltage over all the altitude and temperature range you're likely to need. However, the +/-1.5% looks like it translates to a couple of hundred feet of error at sea level, which would be a real problem.
  • Ken GraceyKen Gracey Posts: 7,401
    edited 2009-06-05 17:13
    humanoido!
    Got the solution for you. Parallax is in the final stages of a small module based upon the http://www.vti.fi/en/products/pressure-sensors/pressure_sensors/ SCP1000 pressure sensor: sold by the manufacturer as the most precise pressure sensor in the world! The version we have designed into a module is functional from 0 to 120 kPA (you can figure out the elevation).
    Today Josh is doing the final code testing and we are sending it to production next week. I could send you one of the prototypes to try out. Being that you live in a high-rise building, you can easily test it from ground level to the 20th floor. Send me an e-mail to remind me and I'll take care of the request next week.
    Sincerely,
    edited 2009-06-06 03:55
    @ dre
    Thank you for the link. This method determines rocket altitude based on accelerometer and time readings. If you have a constant rate of acceleration over time, this equates into distance. An interesting novel approach, but it does not work on kites, which are slow to reach altitude - the rate of climb is not constant or significant enough to register on the accelerometer.
    @ sylvie369
    Thank you for the links. The chart with air pressure versus altitude is especially helpful. The sensor looks like a good one, for thousand foot altitudes and above. Accuracy is a consideration. Ken has come up with exactly what I'm looking for - a very good sensor with amazing accuracy that looks perfect for the application. Your near space balloon project sounds very exciting. Do you have a web site? It would be interesting and useful to see Earth/Space photos at 94,000 feet!
    @ Ken
    Thanks!!!
    edited 2009-06-06 10:25
    Photos of the workshop, launch, and recovery are at
    www.tinyurl.com/balloonworkshop
    Unfortunately, I don't have the onboard video yet.
    Very good news about the Parallax sensor. I was going to spend today searching for more precise sensors, but I guess now I don't have to. Man, this is a good company.
  • dredre Posts: 106
    Oops, sent the wrong link. See if this helps:
    http://geocities.com/SiliconValley/Orchard/6633/altimeter.html
    cheers, David
