Hall Effect Sensor 90217
I'm new to microcontrollers and have started playing with sensors. Currently I'm trying to read an input from the hall effect sensor with no luck. I have checked the sensor· using a simple test and it is working. However, I don't have enough output voltage from the sensor·for the chip to pick up an input. Do I need a different type of sensor or have the chip set up·to read the hall effect as an analog signal rather than a 3.3v input?
I have the spec. sheet and don't understand what V(Sat), Output Saturation Voltage, is.
Malcolm.
Malcolm.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
·The following link shows a typical setup for a BS2 chip:
http://www.parallax.com/Default.aspx?tabid=420
·There is an object in OBEX you can use for testing:
http://obex.parallax.com/objects/98/
@ Leon·- Melexis 90217 Hall-Effect Sensor (Parallax 605-00005)
Post Edited (hover1) : 6/5/2009 12:44:26 PM GMT
I finally got the sensor (its the hall effect 90217 sensor to work). I can now show it pulsing as the magnet passes by and have a counter to count the passes. I followed the schematic to the T and put in the correct sized capacitor, which now seems to light up the LED brighter. I'm still using the 3.3V??. I do see it requires minimum of 3.5V (perhaps 3.5V is for the higher end performance of the sensor). I'm running a gearbox that spins an arm with the magnet at about 80 rpm.
Malcolm.
Since you posted in the Propeller forum, I am assuming you are using the Propeller to interface with the 90217. So you used 3.3V to power the sensor and it worked?· I'm not sure where the LED comes in. Is that just to show the output pulses visually? And what code did you finally end up using to test it? Would be great to share that with us newbies
Jim
