Cameras and Props
Hello,
I'm a bit of a newb looking for advice.
I want to try some computer vision testing with the propeller. What I'm trying to achieve is the following:
Two propeller operated modules.
----On the first, a camera, some other sensors and a transceiver.
----On the second, another transceiver
The first module would be out on a robot for example collecting data and sending it back to the second module that would be connected to a computer running software which can process the information received. The computer would then send back control data to the robot.
What I am having difficulty with is how to get pictures back and into the software. I want to use Roborealm (a very cool bit of computer vision software) to receive the pictures and then issue commands back. If I get camera which outputs an RCA signal www.active-robots.com/products/sensors/sparkfun/light-imaging.shtml (the CMOS one, Product Code: SEN-08739) how can I read an image from this, pass it through the transceivers and get it into the computer?
I can't find much about people using anything other than the CMUcam(bit pricey fro me) with the prop so I'm looking for some solutions using lower cost cameras.
Dan
Dan
Some info here:
http://www.rayslogic.com/propeller/Programming/Cameras/cameras.htm
