Will this code work in a BS1
counter VAR Word
' ' '' ' '' ' ' before eyes move dead pin for 30 second delay ' ' '' ' '' ' '' ' '
FOR counter = 1 TO 20
PULSOUT 13, 690
·PAUSE 5
·PULSOUT 12, 415
·PAUSE 5
·NEXT
GOTO Main:
Main:
DO
IF IN2 = 1 THEN
GOTO Blink1:
ENDIF
IF IN4 = 1 THEN·
GOTO Blink2:
ENDIF
IF IN1 = 1 THEN
GOTO Blink3:
ENDIF
LOOP
' ' '' ' '' ' 'pushbutton ' '' ' '' ' '' ' '
· Blink2:
FOR counter = 1 TO 10
PULSOUT 13, 690
·PAUSE 15
·PULSOUT 12, 415
·PAUSE 15
·NEXT
·FOR counter = 1 TO 15
·PULSOUT 13, 300
·PAUSE 14
·PULSOUT 12, 840
·PAUSE 14
NEXT
GOTO Main:
··· Blink1:·· ''''''Starting routine
··· PAUSE 20000
·PULSOUT 13, 300
·PAUSE 10
·PULSOUT 12, 840
·PAUSE 8
NEXT
PAUSE 2000
PULSOUT 13, 690
·PAUSE 10
·PULSOUT 12, 415
·PAUSE 10
·NEXT
·PULSOUT 13, 300
·PAUSE 10
·PULSOUT 12, 840
·PAUSE 10
NEXT
PULSOUT 13, 690
·PAUSE 10
·PULSOUT 12, 415
·PAUSE 10
·NEXT
· FOR counter = 1 TO 15
·PULSOUT 13, 300
·PAUSE 20
·PULSOUT 12, 840
·PAUSE 20
NEXT
·PAUSE 2500
PULSOUT 13, 690
·PAUSE 8
·PULSOUT 12, 415
·PAUSE 8
·NEXT
·FOR counter = 1 TO 10
·PULSOUT 13, 375
·PAUSE 7
·PULSOUT 12, 840
·PAUSE 9
NEXT
GOTO Main:
Blink3: ''''''ending
·PAUSE 5000
·FOR counter = 1 TO 20
PULSOUT 13, 690
·PAUSE 5
·PULSOUT 12, 415
·PAUSE 5
·NEXT
·PAUSE 10000
·PULSOUT 13, 300
·PAUSE 10
·PULSOUT 12, 840
·PAUSE 5
NEXT
·PAUSE 3000
· FOR counter = 1 TO 20
PULSOUT 13, 690
·PAUSE 5
·PULSOUT 12, 415
·PAUSE 5
·NEXT
·PAUSE 4000
·PULSOUT 12, 840
·PAUSE 15
·NEXT
·PAUSE 1000
·PULSOUT 12, 415
·PAUSE 20
·NEXT
·PAUSE 4000
PULSOUT 13, 300
·PAUSE 15
·NEXT
·PAUSE 1000
·PULSOUT 13, 690
·PAUSE 20
·NEXT
·PAUSE 4000
·PULSOUT 13, 300
·PAUSE 10
·PULSOUT 12, 840
·PAUSE 5
NEXT
PAUSE 5000
PULSOUT 13, 690
·PAUSE 5
·PULSOUT 12, 415
·PAUSE 5
·NEXT
·PAUSE 4000
·PULSOUT 13, 300
·PAUSE 10
·PULSOUT 12, 840
·PAUSE 8
NEXT
PAUSE 3000
·PULSOUT 13, 690
·PAUSE 5
·NEXT
PAUSE 500
PULSOUT 13, 300
·PAUSE 5
·NEXT
PAUSE 2000
PULSOUT 13, 690
·PAUSE 15
·PULSOUT 12, 415
·PAUSE 15
·NEXT
·PULSOUT 13, 300
·PAUSE 14
·PULSOUT 12, 840
·PAUSE 14
NEXT
PULSOUT 13, 690
·PAUSE 15
·PULSOUT 12, 415
·PAUSE 15
·NEXT
·GOTO Main:
PULSOUT 13, 690
·PAUSE 5
·PULSOUT 12, 415
·PAUSE 5
·NEXT
GOTO Main:
Main:
DO
IF IN2 = 1 THEN
GOTO Blink1:
ENDIF
IF IN4 = 1 THEN·
GOTO Blink2:
ENDIF
IF IN1 = 1 THEN
GOTO Blink3:
ENDIF
LOOP
· Blink2:
PULSOUT 13, 690
·PAUSE 15
·PULSOUT 12, 415
·PAUSE 15
·NEXT
·PULSOUT 13, 300
·PAUSE 14
·PULSOUT 12, 840
·PAUSE 14
NEXT
GOTO Main:
··· PAUSE 20000
·PULSOUT 13, 300
·PAUSE 10
·PULSOUT 12, 840
·PAUSE 8
NEXT
PAUSE 2000
PULSOUT 13, 690
·PAUSE 10
·PULSOUT 12, 415
·PAUSE 10
·NEXT
·PULSOUT 13, 300
·PAUSE 10
·PULSOUT 12, 840
·PAUSE 10
NEXT
PULSOUT 13, 690
·PAUSE 10
·PULSOUT 12, 415
·PAUSE 10
·NEXT
·PULSOUT 13, 300
·PAUSE 20
·PULSOUT 12, 840
·PAUSE 20
NEXT
·PAUSE 2500
PULSOUT 13, 690
·PAUSE 8
·PULSOUT 12, 415
·PAUSE 8
·NEXT
·PULSOUT 13, 375
·PAUSE 7
·PULSOUT 12, 840
·PAUSE 9
NEXT
GOTO Main:
·PAUSE 5000
PULSOUT 13, 690
·PAUSE 5
·PULSOUT 12, 415
·PAUSE 5
·NEXT
·PAUSE 10000
·PULSOUT 13, 300
·PAUSE 10
·PULSOUT 12, 840
·PAUSE 5
NEXT
·PAUSE 3000
PULSOUT 13, 690
·PAUSE 5
·PULSOUT 12, 415
·PAUSE 5
·NEXT
·PAUSE 4000
·PULSOUT 12, 840
·PAUSE 15
·NEXT
·PAUSE 1000
·PULSOUT 12, 415
·PAUSE 20
·NEXT
·PAUSE 4000
PULSOUT 13, 300
·PAUSE 15
·NEXT
·PAUSE 1000
·PULSOUT 13, 690
·PAUSE 20
·NEXT
·PAUSE 4000
·PULSOUT 13, 300
·PAUSE 10
·PULSOUT 12, 840
·PAUSE 5
NEXT
PAUSE 5000
PULSOUT 13, 690
·PAUSE 5
·PULSOUT 12, 415
·PAUSE 5
·NEXT
·PAUSE 4000
·PULSOUT 13, 300
·PAUSE 10
·PULSOUT 12, 840
·PAUSE 8
NEXT
PAUSE 3000
·PULSOUT 13, 690
·PAUSE 5
·NEXT
PAUSE 500
PULSOUT 13, 300
·PAUSE 5
·NEXT
PAUSE 2000
PULSOUT 13, 690
·PAUSE 15
·PULSOUT 12, 415
·PAUSE 15
·NEXT
·PULSOUT 13, 300
·PAUSE 14
·PULSOUT 12, 840
·PAUSE 14
NEXT
PULSOUT 13, 690
·PAUSE 15
·PULSOUT 12, 415
·PAUSE 15
·NEXT
·GOTO Main:
You can produce both servo pulses, one after the other, then pause for 20ms so you get around 50 pulses per second.
The BS1 does have a relatively small limit on the number of GOSUBs allowed.· Check the·manual for that.· It may be a limiting factor as well as memory size.
http://www.efx-tek.com/downloads/prop-1_programming_basics.pdf
Also the BS1 doesn't support DO..Loop.
Shawn Lowe
When all else fails.....procrastinate!
