12v car battery to 5volt for Microcontroller, Help!
Has anyone on here successfully connected a microcontroller to a car battery by stepping down the voltage?? If so, do you have the schematics??
I've tried searching this forum and google but come up empty handed. Please Help!!
(13.5 Volts [noparse][[/noparse]typ car voltage] - 5 Volts [noparse][[/noparse]regulator output]) x Current in Amps = Watts of Heat
7.7 Volts Dropped x Current in Amps = Watts of Heat
Basically, the excess voltage has to go "somewhere" and the somewhere is heat. Heat sinks on a the regulators can also help. What you need depends on how much energy you'll be using at 5 volts. If it's just a processor and a couple solid state relays, you're probably just fine with one regulator. If you start drawing some "working" current, it's time to be more thorough about the design.
The alternative would be a switching regulator (buck or boost/buck), but then there are usually a few other external components required. You may be able to find an "off the shelf" solution by looking at some of the Radio Control stuff. They use some of this for "battery eliminators" for the radios, and depending on the application are VERY concerned about wasted energy, less from heat than as it relates to battery life.
John R.
Click here to see my Nomad Build Log
Take a look at the LM1084
________$WMc%____
The Truth is out there············································ BoogerWoods, FL. USA
It is better to use a series resister with the input. Value should be chosen to drop 5v at max current.
propmod_us and propmod_1x1 are now in stock. Only $30. PCB available for $5
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
Post Edited (mctrivia) : 6/3/2009 2:12:12 AM GMT
http://www.seetron.com/an_vpwr1.htm
cheers, David
