Sharing 1-wire device DS2401 with serial line
I have been asked to add a Silicon Serial Number (DS2401) to an existing pcb
that has no I/O lines free.
But there is a bidirectional serial line between a SX28 and a javelin.
I had this idea:
······························ +5V
········ +---+············· · [noparse][[/noparse]4k7]
········ |·3 o··············· ··|
········ |·2 o
+ DQ
·········|·1 o
·········+---+······· |····· ·[noparse][[/noparse]1k0]
······· DS2401(TO92)· V·········|
·····················GND······· |
JavPin o
[noparse][[/noparse]270R]--+
o SxPin
Upon power up, the JavPin remains an input for at least 4 seconds, which should
be long enough for the SX to read the DS2401. After reading, the SxPin becomes
a serial input.
After 4 seconds the JavPin becomes a high output (serial idle state).
The javelin then sends a command to the SX. Speed is 1200 baud so bittime is 833 uSec.
A low bit (startbit) will thus·act as a reset signal to the DS2401, but because of the resistor divider
1k0/270R, when·the JavPin turns high, so will the level at SxPin, regardless wether the
DS2401 has pulled down DQ (Presence Pulse).
After·sending a command, the JavPin is made a serial input waiting for a response from the SX.
If I add enough stopbits to·the javelin serial·bytes, the DS2401 Presence Pulse should be overlapped
by the JavPin being high output and turned into input. The 4k7 would keep the·level high.
Question is: would this strategy work? Or·will the DS2401 interfere with the serial· data streams?
I have no DS2401·so I haven't been able to test it yet.
regards peter
I had this idea:
········ |·2 o
+ DQ
·········|·1 o
JavPin o
o SxPin
a serial input.
regards peter
········ |·2 o
+ DQ
·········|·1 o
······· DS2401(TO92)· |·········|
JavPin o
+--[noparse][[/noparse]4k7]--+
o SxPin
Upon power up, the JavPin is made low to power the DS2401
while the SX waits for a low level at SxPin.
Making JavPin low should give (4k7/10k4)*5V < 2.5V, eg. low level at SxPin
while level at DQ > 2.5V
The SX then reads the DS2401 (reset pulse will make level at DQ < 2.5V).
After reading the SxPin becomes a serial input.
After 4 seconds the JavPin is made a high output (serial idle state).
Now the javelin can send a command. The stopbit will power·off
the DS2401 so it can not interfere.
Is that a better approach?
Edit: with the 4k7 at JavPin, reading the DS2401·won't work because as soon as DQ is
released the level at SxPin drops below 2.5V
What if I made the SxPin TTL threshold (1.4V)? That might work
if the level stays above 1.4V until DQ is pulled low.
Making the resistor 10k would prevent the JavPin to detect low
when receiving serial data so the resistor must be 4k7.
regards peter
Post Edited (Peter Verkaik) : 6/2/2009 7:06:09 PM GMT
Unfortunately the DS2411 does not come in TO92 package
and I really don't want any smd package.
regards peter
········ |·2 o
+ DQ
·········|·1 o
JavPin o
+--[noparse][[/noparse]3k9]--+
o SxPin
Making JavPin low should give (3k9/9k6)*5V = 2V, eg. low level at SxPin CMOS
while level at DQ =·2.6V
The SX then switches to TTL mode and reads the DS2401 (reset pulse will make level at DQ =·0.88V).
Releasing the SxPin makes the level 2V again, but due to TTL mode this is read as high.
After reading the SxPin becomes a serial input using CMOS mode.
regards peter
I'd still be inclined to incorporate a supervisor, just for simplicity and reliability. Here's a circuit that employs a Microchip MCP120. It's open-drain and holds the /RST pin low for 350ms after power-up:
The test schematic looks like this:
' Test shared 1-wire connection
' RA.1·
RX USB2SER
'················· +5V
'·················· |····· 3/nc
'················ [noparse][[/noparse]4k7]···· |
'·················· | 2/DQ|·· |
' RA.0· ---+-[noparse][[/noparse]270R]-+
|·· | DS2401
'······· [noparse][[/noparse]1k0]············· | 1/GND
'········· |··············· V
' RA.3· ---+· simulates 1200 baud serial out (startbit is low for 833 uSec)
'············ The DS2401 should not detect this as OWRESET signal.
' This program scans the 1-Wire bus and when a device is detected it will
' read and display its serial number. Then RA.3 is pulsed low for 833 uSec
' and then the 1-Wire bus is scanned again but no device should be found.
The attached program is a modified example I found in the help for OWRESET command.
The picture shows no device is found after pulsing RA.3 low
Pulling RA.3 low gives (1k/(1k+270R+4k7))*5V = 0.84V @RA.0
and ((1k+270R)/(1k+270R+4k7))*5V = 1.06V @DQ
According to the DS2401 datasheet the maximum low level at which the DS2401
detects a resetpulse is 0.3V
Pulling RA.0 low gives (270R/(270R+4k7))*5V = 0.27V
and thus the DS2401 detects the owreset signal.
After reading the serial number RA.0 can turn to serial output driving
high and low (which overrides·DQ).
regards peter
Post Edited (Peter Verkaik) : 6/5/2009 2:43:39 PM GMT
