Need help with simulating a shaft speed signal
I am wanting to use a BS2 to simulate a shaft speed signal for a shaft speed monitor.· I need to·come up with 5 different·simulated shaft speeds.· The shaft uses a 48 tooth tone wheel with a hall effect sensor.· I need to output a·signal from 24.2kHz to 228kHz.· Can anyone help me with this?
Just google 555 oscillator and you'll be swamped with circuits.
Cheers,
Tom Sisk
http://www.siskconsult.com
Another source for info is in experiments#15,16,and 19 of the Stampworks Manuel.
_______$WMc%___
The Truth is out there············································ BoogerWoods, FL. USA
Cheers,
Tom Sisk
_________$WMc%________
