building a cad program — Parallax Forums
science_geekscience_geek Posts: 247
edited 2009-06-02 19:37 in Propeller 1
i want to build a cad program for the prop to be used to controll my cnc mill.·i would like it to be much like declaring a vector as far as drawing a line goes, you give it an x,y start, a direction, and a magnitude, but i also want to do depth but only on the 2d side so something like a different color representing depth, and which one to cut first. the only way i see this working is with·6 arrays, there would be quite a bit of info, so should i us a uSD card or is there enough ram to be able to store all this info, has anyone tried anything similar, any thoughts or help is appreciated
  • LeonLeon Posts: 7,620
    edited 2009-06-02 04:31
    It's more usual to have the CAD program running on a PC. The Propeller would be better employed controlling the steppers/servos.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    edited 2009-06-02 04:42
    science_geek,
    I think it's possible... Chip has even made mention of having a small schematic editor/simulator running completely from the Propeller. For storage though, I would go with a standard format ... what comes to mind for me is GDSii, but that's just the CAD world that I live in, there are certainly other CAD drawing formats that could be used. If you are interested, I have a GDSii parser that I wrote in Visual Basic that could easily be implemented on another programming platform... i.e. the Propeller that I could send your direction.
    Beau Schwabe
    IC Layout Engineer
  • KyeKye Posts: 2,200
    edited 2009-06-02 14:25
    If you were to do such a project you would need to use multiple propeller chips, one for graphics and one for the program, keyboard, mouse and sd card. Drawing lines requires a large memory buffer so it would not be possible on just one chip - Unless you really optimize everything and have some tiny code.
    Nyamekye,
  • RaymanRayman Posts: 16,383
    edited 2009-06-02 18:18
    I've mulled over the possiblility of doing a "small schematic editor/simulator" myself... I think it would be neat. But, a lot of work for not much reward..
  • science_geekscience_geek Posts: 247
    edited 2009-06-02 19:05
    Beau, if you could please send that I could look at to get an idea of how something like that would work
    kye, I have already planned on using several props as im incorporating this into my A.N.A project, but i am using a serial display, so the graphics drawing would only use the data thats stored in the array and would only use one command to draw it all, dont know how long it would take, but i know there is a vsync command i could use to sync up and not erase the·whole screen,
    rayman, it would be a great reward, cause who really has a cad program·on a device that is the size of your palm that·has sub programs that can·control basic·functions in my garage and on my go kart
    would my vector array methods work, or is there a better·way to·do·this, i·use·cad all the time, but i dont generally understand all the·proggramming that goes into the, i have·coded a wire frame builder that would rotate and redraw a little square, but it was coded to draw all the lines in code,·and·thats my extent of graphics
    edited 2009-06-02 19:30
    science_geek.
    This Visual Basic code will parse a GDSii standard file into human readable text
    GDSiifunctions.bas
    Attribute VB_Name = "Module1"
    Sub ReadGDS(FileName$)
        DesignMenu.Slider1.Visible = "True"
        Open FileName$ For Binary As 1
             FileSize = LOF(1)
             Debug.Print "---------------------------------------"
             Debug.Print TestFile$
             Debug.Print FileSize
             DataSize = 0
             While Seek(1) < FileSize And Sw1 = 0
                   Pcnt = Int((Seek(1) / FileSize) * 100)
                   DesignMenu.Slider1.Value = Pcnt
                   DataSize = TBSI - 4
                   Record = HexWord
                   'Debug.Print "Record Type -"; Record, "Record Size -"; DataSize
                   ExitButton = DesignMenu.Slider1.Tag
                   If ExitButton = "Slider Click" Then
                      GoTo ExitSub
                   End If
                   Select Case Record
                   Case "0000"  'End of File
                        GoTo ExitSub
                   Case "0002"  'HEADER
                        Debug.Print Record, "GDS Version ="; Str$(TBSI)
                   Case "0102"  'BGNLIB
                        Debug.Print Record, BGNdata
                   Case "0206"  'LIBNAME
                        Debug.Print Record, "Library Name ="; Input(DataSize, #1)
                   Case "0305"  'UNITS
                        GridUnit = Str$(EBRN)
                        MeterUnit = Str$(EBRN)
                        Debug.Print Record, "Grid Unit ="; GridUnit
                        Debug.Print , "MeterUnit ="; MeterUnit
                   Case "0400"  'ENDLIB
                        Debug.Print Record, "Library End"
                   Case "0502"  'BGNSTR
                   Case "0606"  'STRNAME
                        Debug.Print Record, "Structure Name ="; Input(DataSize, #1)
                   Case "0700"  'ENDSTR
                        Debug.Print Record, "Structure End"
                   Case "0800"  'BOUNDARY
                        Debug.Print Record, "Boundary Start"
                   Case "0900"  'PATH
                        Debug.Print Record, "Path Start"
                   Case "0A00"  'SREF
                        Debug.Print Record, "Reference Structure Start"
                   Case "0B00"  'AREF
                        Debug.Print Record, "Array Start"
                   Case "0C00"  'TEXT
                        Debug.Print Record, "Text Start"
                   Case "0D02"  'LAYER
                        Debug.Print Record, "Layer ="; TBSI
                   Case "0E02"  'DATATYPE
                        Debug.Print Record, "Data type ="; TBSI
                   Case "0F03"  'WIDTH
                        Debug.Print Record, "Width ="; FBSI
                   Case "1003"  'XY
                        Debug.Print Record, "XY coordinates ="; XY(DataSize)
                   Case "1100"  'ENDEL
                        Debug.Print Record, "Element End"
                   Case "1206"  'SNAME
                        Debug.Print Record, "Referenced Structure Name ="; Input(DataSize, #1)
                   Case "1302"  'COLROW
                        Debug.Print Record, "Columns ="; TBSI
                        Debug.Print , "   Rows ="; TBSI
                   Case "1400"  'TEXTNODE
                        Debug.Print Record, "Not Used"
                   Case "1500"  'NODE
                        Debug.Print Record, "Node Start"
                   Case "1602"  'TEXTTYPE
                        Debug.Print Record, "Text Type ="; TBSI
                   Case "1701"  'PRESENTATION
                        Debug.Print Record, "Text presentation ="; PRESENTATION
                   Case "1906"  'STRING
                        Debug.Print Record, Input(DataSize, #1)
                   Case "1A01"  'STRANS
                        Debug.Print Record, "Text Transformation ="; STRANS
                   Case "1B05"  'MAG
                        Debug.Print Record, "Magnification Factor ="; EBRN
                   Case "1C05"  'ANGLE
                        Debug.Print Record, "Angular Rotation ="; EBRN
                   Case "1F06"  'REFLIBS
                        Debug.Print Record, "Reference Libraries ="; Input(DataSize, #1)
                   Case "2006"  'FONTS
                        Debug.Print Record, "Text Font ="; Input(DataSize, #1)
                   Case "2102"  'PATHTYPE
                        Debug.Print Record, "Path type ="; TBSI
                   Case "2202"  'GENERATIONS
                        Debug.Print Record, "Backup Copies ="; TBSI
                   Case "2306"  'ATTRTABLE
                        Debug.Print Record, "Attribute definition file ="; Input(DataSize, #1)
                   Case "2406"  'STYPTABLE
                        Debug.Print Record, "Unreleased Feature ="; Input(DataSize, #1)
                   Case "2502"  'STRTYPE
                        Debug.Print Record, "Unreleased Feature ="; TBSI
                   Case "2601"  'ELFLAGS
                        Debug.Print Record, ELFLAGS
                   Case "2703"  'ELKEY
                        Debug.Print Record, "Unreleased Feature ="; FBSI
                   Case "2A02"  'NODETYPE
                        Debug.Print Record, "Node Type ="; TBSI
                   Case "2B02"  'PROPATTR
                        Debug.Print Record, "Attribute Number ="; TBSI
                   Case "2C06"  'PROPVALUE
                   Case "2D00"  'BOX
                        Debug.Print Record, "Box Start"
                   Case "2E02"  'BOXTYPE
                        Debug.Print Record, "Box Type ="; TBSI
                   Case "2F03"  'PLEX
                        Debug.Print Record, FBSI
                   Case "3003"  'BGNEXTN
                   Case "3103"  'ENDEXTN
                   Case "3202"  'TAPENUM
                        Debug.Print Record, "Tape number ="; TBSI
                   Case "3302"  'TAPECODE
                        Debug.Print Record, "Tape code ="; TBSI
                   Case "3401"  'STRCLASS
                        Debug.Print Record, "Cadence Internal ="; STRCLASS
                   Case "3503"  'RESERVED
                        Debug.Print Record, "RESERVED ="; Input(DataSize, #1)
                   Case "3602"  'FORMAT
                        Debug.Print Record, TBSI
                   Case "3706"  'MASK
                   Case "3800"  'ENDMASKS
                        Debug.Print Record, "Mask End"
                   Case "3902"  'LIBDIRSIZE
                        Debug.Print Record, "Library Directory Size ="; TBSI
                   Case "3A06"  'SRFNAME
                        Debug.Print Record, "Spacing Rules file ="; Input(DataSize, #1)
                   Case "3B02"  'LIBSECUR
                        Debug.Print Record, "Access Control List ="; LIBSECUR(DataSize)
                   Case "3C00"  'BORDER
                        Debug.Print Record, "Border Start"
                   Case "3D00"  'SOFTFENCE
                        Debug.Print Record, "Soft fence Start"
                   Case "3E00"  'HARDFENCE
                        Debug.Print Record, "Hard fence Start"
                   Case "3F00"  'SOFTWIRE
                        Debug.Print Record, "Soft wire Start"
                   Case "4000"  'HARDWIRE
                        Debug.Print Record, "Hard wire Start"
                   Case "4100"  'PATHPORT
                        Debug.Print Record, "Path port Start"
                   Case "4200"  'NODEPORT
                        Debug.Print Record, "Node port Start"
                   Case "4300"  'USERCONSTRAINT
                        Debug.Print Record, "User constraint Start"
                   Case "4400"  'SPACER ERROR
                        Debug.Print Record, "Spacer error Start"
                   Case "4500"  'CONTACT
                        Debug.Print Record, "Contact Start"
                   End Select
                   If Mid$(Record, 1, 2) = "28" Then    'LINKTYPE
                      Temp = Seek(1)
                      Seek #1, Temp - 1
                      Debug.Print "28", "Unreleased Feature"; TBSI
                   End If
                   If Mid$(Record, 1, 2) = "29" Then    'LINKKEYS
                      Temp = Seek(1)
                      Seek #1, Temp - 1
                      Debug.Print "29", "Unreleased Feature"; FBSI
                   End If
                   DoEvents
                 Wend
    ExitSub:
        Close #1
        DesignMenu.Slider1.Visible = "False"
        DesignMenu.Slider1.Tag = ""
    End Sub
    Function BGNdata()
             Dim TempData(12)
             apm = "a"
             apa = "a"
             For N = 1 To 12
                 Temp = TBSI
                 If N = 1 Or N = 7 Then Temp = Temp + 1900
                 If N = 4 Or N = 10 And Temp > 12 Then
                    Temp = Temp - 12
                    If N = 4 Then apm = "p"
                    If N = 10 Then apa = "p"
                 End If
                 TempData(N) = Trim$(Str$(Temp))
                 If Len(TempData(N)) < 2 Then
                    TempData(N) = "0" + TempData(N)
                 End If
             Next N
             Modify_Date = TempData(2) + "/" + TempData(3) + "/" + TempData(1)
             Modify_Time = TempData(4) + ":" + TempData(5) + ":" + TempData(6) + apm
             Access_Date = TempData(8) + "/" + TempData(9) + "/" + TempData(7)
             Access_Time = TempData(10) + ":" + TempData(11) + ":" + TempData(12) + apa
             Temp = Modify_Date + " " + Modify_Time + " -- " + Access_Date + " " + Access_Time
             BGNdata = Temp
    End Function
    Function EBRN()
             'Eight Byte Real Number
             Dim Mantissa As Double
             Dim TempN As Double
             Dim B(7)
             B(7) = Asc(Input(1, #1))
             B(6) = Asc(Input(1, #1))
             B(5) = Asc(Input(1, #1))
             B(4) = Asc(Input(1, #1))
             B(3) = Asc(Input(1, #1))
             B(2) = Asc(Input(1, #1))
             B(1) = Asc(Input(1, #1))
             B(0) = Asc(Input(1, #1))
             Sign = 1 - (Int((B(7) And &H80) / &H80) * 2)
             Exponent = (B(7) And &H7F) - 64
             Weight = 1
             For N = 6 To 0 Step -1
                 For Bit_ = 7 To 0 Step -1
                     BitPosition = 2 ^ Bit_
                     Weight = Weight * 2
                     BitValue = Int((B(N) And BitPosition) / BitPosition) * (1 / Weight)
                     Mantissa = Mantissa + BitValue
                 Next Bit_
             Next N
             TempN = (Sign * Mantissa) * (16 ^ Exponent)
             EBRN = TempN
    End Function
    Function ELFLAGS()
             D1 = Asc(Input(1, #1))
             D0 = Asc(Input(1, #1))
             DataSize = DataSize - 2
             TemplateData = Int((D1 And 128) / 128)
             ExternalData = Int((D1 And 64) / 64)
             If TemplateData = 0 Then
                TD = "Template data is off"
             Else
                TD = "Template data is on"
             End If
             If ExternalData = 0 Then
                ED = "ExternalData data is off"
             Else
                ED = "ExternalData data is on"
             End If
             Temp = TD + " " + ED
             ELFLAGS = Temp
    End Function
    Function FBRN()
             'Four Byte Real Number
             Dim TempN As Double
             Dim B(3) As Byte
             Sign = 1 - (Int((B(3) And &H80) / &H80) * 2)
             Exponent = (B(3) And &H7F) - 64
             Weight = 1
             For N = 2 To 0 Step -1
                     Weight = Weight * 2
                 Next Bit_
             Next N
             FBRN = TempN
    End Function
    Function FBSI()
             'Four Byte Signed Integer
             D = Hex$(Asc(Input(1, #1)))
             C = Hex$(Asc(Input(1, #1)))
             B = Hex$(Asc(Input(1, #1)))
             A = Hex$(Asc(Input(1, #1)))
             FBSI = Val("&H" + D + C + B + A)
    End Function
    Function HexByte(D0)
             Temp = Hex$(D0)
             If Len(Temp) = 1 Then Temp = "0" + Temp
             HexByte = Temp
    End Function
    Function HexWord()
             HexWord = HexByte(D1) + HexByte(D0)
    End Function
    Function LIBSECUR(DataSize)
             JunkFiller = Input(DataSize, #1)
             LIBSECUR = "Access Control List"
    End Function
    Function PRESENTATION()
             Font_ = (D1 And 12) \ 4
             Vert = (D1 And 48) \ 16
             Horz = (D1 And 192) \ 64
             Select Case Vert
                    Case 0
                         VertJust = "Top"
                    Case 1
                         VertJust = "Middle"
                    Case 2
                         VertJust = "Bottom"
             End Select
             Select Case Horz
                    Case 0
                         HorzJust = "Left"
                    Case 1
                         HorzJust = "Center"
                    Case 2
                         HorzJust = "Right"
             End Select
             Temp = "Font = " + Str$(Font_) + " " + VertJust + " " + HorzJust
             PRESENTATION = Temp
    End Function
    Function STRANS()
             XaxisReflect = (D0 And 1)
             AbsoluteMagnification = Int((D1 And 32) / 32)
             AbsoluteAngle = Int((D1 And 64) / 64)
             If XaxisReflect = 0 Then
                 XR = "X-Axis is not reflected"
             Else
                 XR = "X-Axis is reflected"
             End If
             If AbsoluteMagnification = 0 Then
                 AM = "Absolute Magnification is off."
             Else
                 AM = "Absolute Magnification is on."
             End If
             If AbsoluteAngle = 0 Then
                 AA = "Absolute Angle is off."
             Else
                 AA = "Absolute Angle is on."
             End If
             Temp = XR + " " + AM + " " + AA
             STRANS = Temp
    End Function
    Function STRCLASS()
             STRCLASS = "Cadence internal use only"
    End Function
    Function TBSI()
             'Two Byte Signed Integer
             TBSI = Val("&H" + B + A)
    End Function
    Function XY(DataSize)
             Temp = ""
             While DataSize > 0
                   DataSize = DataSize - 8
                   tempX = Str$(FBSI)
                   tempY = Str$(FBSI)
                   Temp = Temp + "(" + tempX + "," + tempY + ")"
             Wend
             XY = Temp
    End Function
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 6/3/2009 6:08:10 PM GMT
    I wouldn't try to draw the lines with graphics! The ROM font can draw all the components and wires of a schematic...
