HB-25 Motor Controller Code
· Can anyone give some help to me please!
·I am a new to programming and was wondering If anyone could give me a small sample of code to study on the HB-25 motor controller.
The test sample that Parallax has on thier website is of no use to me! I tried to change the values in the sample code, but then it doesn't work.
I am trying find some code that will allow a ping sensor to control 2 HB-25's like if they were sevos if it possible.
·All or any help! greatly appreciated.
·Thank's
·Ln Zar
·Thank's
·Ln Zar
It's a relatively simple process. It might help if you mention the uC that you're using.
You stated that you are a newbie. My advice is to add some more info on Your project(s) when posting in these forums.
Things like what Micro controller Your using
The sample code Your modifying
What You want the out come to be?
Use the Attachment Manager to upload these files with Your posts.
Take a look at SRLM's Avatar, the first thing You see is a PING sensor,next is a rubber track drive.If You look just behind the drive sprocket theirs a Servo motor. What better place to get info for what your after is there?
I was once a newbie,just trying to help.
__________$WMc%_______
The Truth is out there············································ BoogerWoods, FL. USA
Ln Zar
