BS1 using RC servo coding
Servo #1
I need some help in writing a code for·my BS1 using a potentiometer to control a servo. I'm using pin 0 on the potentiometer and pin 1 for the servo. I want the servo's movements to echo the potentiometer's movement.
Servo #2
I need this servo to move with a push button. When the push button is pressed·and released the servo moves all the way right then back to center as fast as possible.
Any help with this·project would be very appreciated!
Jim
Servo #2
Jim
- Stephen
1) Read the potentiometer value and display it using DEBUG?
2) Move a servo to a position proportional to a number?
3) Wait for a pushbutton to be pressed then released?
Do look at "Basic Stamp 1 Application Notes" here: www.parallax.com/tabid/440/Default.aspx
Can ·I speak with you over the phone? Please send me your contact information to my email. studiomagic@cableone.net
I have tried some codes. I really need somebody who understands how to write the codes.
-jim
The way these forums work is that you describe what you're trying to do. You provide the source code you're using and/or a schematic of how you have things connected and describe what's happening when you try it. Someone or several someones will reply with an explanation or suggestions for you to try. If you want someone to solve your problem for you, you need to hire a consultant. Other than that, you will have to do some work. Generally, you'll find that people here are willing to help, but you have to supply enough information to work with. You also have to be willing to follow suggestions.
Thanks for your help.
jim
