Propeller Datapath Available?
I'm taking an introductory computer architecture course at my university and we're working with a (simulated) microprocessor called the LC-3. We've gone through every aspect of the design from the transistor up to assembly programming. I've particularly enjoyed the section where we trace the instruction paths for the various assembly commands. What I was wondering is if there is an available datapath sheet for the Propeller? I'm sure that there must be one, my concern being that it may be considered property of Parallax.
In case the terminology differs, here is what the LC-3 datapath is like: www.liafa.jussieu.fr/~carton/Enseignement/Architecture/Cours/LC3/datapath.png
Is there anything similar for the Propeller?
Jazzed has exactly such a project going on here:
http://forums.parallax.com/showthread.php?p=807328
Although it seem he does not want to publish the resulting Verilog.
Nutson also has an FPGA COG project here:
http://forums.parallax.com/showthread.php?p=762775
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 6/1/2009 7:52:26 AM GMT
Now timing analysis of pathways through software is also interesting. I thought that in general this was an unsolvable problem. The Halting Problem and all that.
The only time I have ever seen and used such a tool was for aircraft control systems that were written in a language called LUCOL. They could do it there because Lucol did not have any loop constructs. No way to create a loop in a module at all, no GOTO etc. So all the pathways through the code were easily discovered and a cycle accurate report of execution time could be produced on every compilation.
If your code has loops it's hard. I imagine that if your code is self modifying as is essential for PASM applications its pretty much impossible.
Leon
