Remote serial LCD display?
Hello All
I need to send serial data from a BS2·to a Parallax serial LCD that is about 1600 feet away from the BS2.I have 4 existing spare wires (12GA) that I can use.
The BS2 is located at the front gate, It controls the gate operation and a keypad for employee access along with a serial LCD so the employee can see that they have pressed the correct keys on the keypad.
My Chief Engineer has requested a LCD display in the control room that will display the same data seen at the front gate.
My Question is how to amplify a serial signal to travel a long distance (1588feet) with as few parts as passable?
I feel any answers to this would be beneficial to all BS2 users
Thanks in Advance
________$WMc%____
The Truth is out there············································ BoogerWoods, FL. USA
Thanks in Advance
________$WMc%____
Cheers,
Tom Sisk
http://www.siskconsult.com
I'll research Your suggestions.
The RS422/485 did get Me to thinking about a -12volt/+12volt setup, since I already have a 24volt transformer with a center tap.The RS422/485 transceiver might do this for Me?
____Thanks Again_________$WMc%_______
Cheers,
Tom Sisk
I downloaded the data sheets for the SN75176, But I really couldn't determine a circuit configuration to use it.I have never used this chip before so its all new to Me. Do I need two of these 75176,one at each end? Do You have a generic circuit for a similar use with this chip as mine?
I also downloaded the data sheets for the LM311, This looks promising as well but I have never used this chip either. I was hoping for some generic example circuits in the data sheets, but I really didn't see anything that applied to My project.
Any additional toughts or Ideas·would be great!
___ThankAgain___________$WMc%______
The 75176 is an older chip and continues to be used simply because it does a great job. Also has variations with built-in overvoltage protection. Look it up on DigiKey.
The LTC490 or LTC491 will also work.
Cheers
Tom Sisk
The LTC490 is just what I was looking for. The example circuits are great too.These examples I can·understand.
Thanks Again
_____$WMc%______
I'll check out Jan Axelson's Book.
I deal with serial communications all day at work. I understand most of the protocols but I haven't really dealt with the hardware that makes all this happen. The book sounds like a good read.
Thanks Again________$WMc%________
