Photodiode, High speed count
I am very new to Stamps, mine is in the mail, but·I have been reading code and reading these forums for about 2 years now. I cant seem to find any information on photodiodes to do what i need.
I am considering using a laser diode and photo diode to send and receive a signal. The laser will reflect of a nut spinning approx 80,000 RPM (highest worse case).·The·fiber optic will then send the·signal to the photo diode mounted on the board.· I currently have an "ebay" laser. I believe 5 mW 5volt· 550?(red) wavelength.·
Here is my question.·Can the·photodiode be hooked directly to the stamp pin, or is auxiliary circuit·required?·This auxiliary circuit, does it have the ability to adjust the voltage to the stamp to make sure that the photo diode only sees a full reflection of light and not just a partial fraction of light. Basically, as the nut rotates it gives less and less light to the diode, until it reaches a theoretical “0” being the corner of the nut. In real world, there is still a partial fragment of that will reflect off the less than perfect nut.· I would like to cut off this none full output to prevent erroneous results.·
I don’t want to use infrared.·
·Is a hall sensor a better option in this case?
I apologize if I sound half baked, this is the one area I cant seem to find what I need.
Thank you,
DP
(ΜΟΛΩΝ ΛΑΒΕ[noparse];)[/noparse]
Thank you,
DP
I am going to assume that you are using a hex nut, so you will have 6 reflective surfaces. At 80,000 RPM that would produce an output signal with a frequency of 8,000 Hz. A photo diode produces a relatively small signal when light falls on it, and will probably need to be amplified and converted to a logjc level pulse to be counted. At such a low frequency almost any op amp that operates from a single supply should work.
You may also find that a red led and phototransistor would also work, and that the phototransistor is sensitive enough that it could be hooked directly to the prop pin with only the pull up resistor being required.
In either case the mounting and alignment of the source/emitter and the reflectivity of the nut will be the most critical factors.
It was my understanding that a phototransitor would not work due to the speed involved. That is why I was planning to use a diode. Athought i would be happy to use if it fits my application.
You would be correct on the hex nut 6 side. 8000hz
Would I use an op amp circuit similar to what is used with the infra red circuits?
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 5/31/2009 5:36:02 AM GMT
· Do you have a resource avaliable that I may look at? I would like to look at this more....
··Can you elaborate on the multi-voltage supply? what are the requirments for the circuit?
I have a paranoia for things·I cant see. I actually have no real reason.
I have seen most of the people doing exactly what i am doing, and just assumed do the same. I am trying to not to reinvent the wheel, as I have very little background in electronics. I may try opto switch.
DP
The voltage across the phototransistor will be a constant 6.4V, which keeps the Miller capacitance from having to charge and discharge with varying current. The divider values and ratio will depend on your app.
Post Edited (Phil Pilgrim (PhiPi)) : 5/31/2009 7:47:29 PM GMT
Leon
Left to right
Componets are as follows
phototransistor, (npn device?) , two resistors (approx value?),·(logic symbol?), where is the optioisolator? I am still a little confused on the circuit. what gives me the ablity to adjust the cutoff point at which light will no longer act as a signal? The resistor value before the junction? I want to make sure i have a definitive on, off, for my count.
There may be a few mechanical options i can take such as painting the nut black and "shinning" up the flat spots. But I am trying to gather knowledge on the electrical side.
If you have any more specs on the exact parts used in the circuit above i would really appreciate it.
Thanks again,
DP
Post Edited (ΜΟΛΩΝ ΛΑΒΕ[noparse];)[/noparse] : 6/2/2009 3:51:56 PM GMT
EDIT: moved to new thread, see below... thanks
No matter how much you push the envelope, it'll still be stationery.
Post Edited (CounterRotatingProps) : 6/2/2009 8:36:23 PM GMT
I think that topic should be started in a new thread. Short answer: at those speeds, a photodiode would be a more appropriate receiver.
http://forums.parallax.com/showthread.php?p=812304
Post Edited (CounterRotatingProps) : 6/2/2009 8:35:17 PM GMT
One question i do have, i was reading the process controll pdf, and came across the tach diagram.
will this work for my application? Is it still nessicary to clean up the signal w/ a 74HC14?
I have attached the ciruit from the parallax PC manual.
Would this ciruit work if i simply replaced the emitter and reciever to something matched to my wavelength.
It appears there are more "matched" sets for sale in the IR range. I am going to give these a shot as well two. I just want to make sure i have an accurate signal before i procede.
DP
Having a couple of problems.
First i had to switch the transistor to long leg vss and short leg vdd to get any data. There is no flat marking denoting cathode. This seems backwords, but maybe not?
Anyway, then·I had to increase the resistance to Rc to 10.2kΩ, to get data.
Now when i say data, i mean i was getting results, not good results. I was getting an average of 62 with a range from 52 to 74, with a mode of 64.
The emmiter hooked to vdd not a pin.
HIGH 9······························· 'red led on
COUNT 8,300, tach1··········· ' count pin 8
DEBUG DEC tach1················
LOW 9······························· 'red led off
I am holding the reciever over the emmiter by hand. but the emiiter is stationary.
the red led in the program is just an led on the board to tell me the count is in session.
Why am i getting these values? where have i gone wrong?
DP
Post Edited (ΜΟΛΩΝ ΛΑΒΕ[noparse];)[/noparse] : 6/8/2009 3:22:19 AM GMT
