About the Parallax RFID Rectangle Tags ( Parallax Code 28141 ) — Parallax Forums
markustermarkuster Posts: 184
edited 2009-06-01 20:56 in BASIC Stamp
Hi
I have a BS2-IC Stamp and a Card Reader.
The Card Reader is not from Parallax.
I would like to buy the Parallax RFID Rectangle Tag ( Parallax Code 28141 )
Do you know the technical specifications about the
Parallax RFID Rectangle Tags of Parallax?
( Code 28141 )
Thanks , Mark
    edited 2009-05-31 04:26
    They are 125khz passive tags. The tag sends a start byte, 10 data bytes and a stop byte. It is hard to know without testing if they will work with your system but if the frequencys are the same it might not hurt to try.
    - Stephen
  • markustermarkuster Posts: 184
    edited 2009-06-01 19:10
    I think that Parallax could add more information about the product because
    this information : "54mm x 85mm Rectangle Tag" is absolutely
    poor.
    It is very important to know about the manufacturer tech. specifications.
    I would like to buy some cards and I don't want surprises.
    For this reason all information available will be usefull.
    Thanks, Mark
    Since the tags sold by Parallax are intended to be used and work with their readers ( and do so well) there needs to be no other info. If you need a tag for your specific reader you should go to a site that makes tags and can give you specific info on what works with your reader. What reader are you trying to use?
    - Stephen
