Propeller USB Prototype board
Anyone know what the voltage rating of the input capacitor on the USB Prototype board?
I plan to run this board off "12VDC" vehicle power which may be as high as 15 VDC.
The regulator is not a problem, but I don't know the voltage rating of the input capacitor.
I realize I could install an additional regulator to limit the voltage to a lower value, but would like to avoid that if it is not necessary.
Sigurd, aka KJ1K
Sigurd, aka KJ1K
How much current are you planning on drawing? If it's more than a little (50ma?) then you'll need to add another regulator or two to step down the voltage. Otherwise, it's dropping 7-10 volts.
Therefore, you will need to add a 10uF 25V(minimum) electrolytic capacitor to the input (after the switch).
How much current is your board drawing because heat may be a factor? Don't forget to use an inline fuse.
· Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
· Search the Propeller forums (via Google)
EDIT -- Verified with ohmmeter that both of those tantalum caps are across the regulator outputs, not inputs.· The 10 uF cap between VinSw and Gnd does not seem to be installed.
Post Edited (localroger) : 5/31/2009 5:37:39 PM GMT
