SD Card Adapter
I have an SD card socket, and I want to make an SD card module.... Does anyone have·a pinout of the card slot?· All the ones I've seen don't have all the pins shown, just the ones that are connected....
Thanks.
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
Post Edited (Vaati) : 6/19/2009 4:04:56 AM GMT
Thanks.
Go to spark fun (www.sparkfun.com) and they sell a sd card breakout board which has the needed connections. They also show the schematic on their site.
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Please note: Due to economic conditions the light at the end of the tunnel will be turned off until further notice. Thanks for your understanding.
www.warrantyvoid.us/tiki-index.php?page=Tutorial
Is has the reference you need to get your own SD connection running with what
you have. Based on what I saw at the Library, you'll be up and running tonight.
OBC
New to the Propeller?
Thanks.
You *should* be in business. ?
OBC
Thanks for the help and links!
Thanks.
The SD Card interface isn't like the Prop Plug interface at all, which I think is what you may have been thinking about.
You COULD, however, put an LED on the "Card Inserted" switch/tab. This way, the LED lights when a Card is properly inserted.
Thanks.
Thanks.
So, how would I connect an LED that lights up when data is being transmitted to and from the SD card? I know I need an LED and resistor, but a schematic, picture, or some other graphic is just what I need....
Thanks again.
Thanks.
Thanks.
Thanks.
BTW, this is a good chance to experiment. Try something, see if it works. Let stuff blow up and learn from it.
http://www.kingmax.com/material/download/3/sd.pdf
There's a schematic on page eight, and I was wondering what those caps are for. Does anyone know? Also, would that circuit for the prop?
Thanks.
I just left the keyboard unplugged when I ran PropDOS, so after connecting with the brand new SD card, it would abort so as to prevent what could occur when it wants to open files when there are none to be opened.
Well, I am going to make my deranged SD breakout board into a proper module tonight, which means I have about... 2 hours. Could someone PLEASE tell me how to have an LED that goes on when power is given to the SD card on the proper pins (Vdd, Vss1, Vss2) and when the SD card is in the slot. i.e.; if either power or the card is removed, the LED would go off.
Any ideas, documents, .pdfs, etc that would show/explain how to do that...?
Thanks for a place to put my ideas on paper, or rather, a url.
but when I run Femtobasic nothing , I have the card formatted and everything but then I looked in the Femtobasic PDF and it states to use P8-P11 for the prop proto board does anyone know what gives?? What pins from the prop should be connected to the SD card?
If you are using the Parallax Prop Proto board ???
Well, you will be able to buy my little SD Card Adapter very soon-- perhaps by Teusday. I figured out how to connect the Card Insterted LED: just put the SD card and the LED in SERIES!! I put *everything* in parallel so there isn't any drop in voltage. I actually had to ask my older brother, who knows only what I have told him about electronics and circuits.
I will be putting a link to my SD Card Adapter in my signature by Monday, and it will hopefully be up on Instructables by then as well.
Thanks for the forum space.
So, could you give some feedback on the outlook on this project?· Will it sell?· Will you buy one?? (no pressure
Thanks.
Very clean looking. Pretty big.
propmod_us and propmod_1x1 are now in stock. Only $30. PCB available for $5
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
Post Edited (mctrivia) : 6/19/2009 4:11:44 AM GMT
I don't think even ucontroller could get their price that low...
I am sure you will find buyers.
Post Edited (mctrivia) : 6/19/2009 4:21:13 AM GMT
