Can 2 Basic Stamps be I2C masters controlling the same slave?
I upgraded to a BS2PX and had an old BS2P laying around so I decided to add the old BS2P to my bot and use it to outsource non-critical tasks, such as speech and other "fun" or cosmetic tasks (blinking lights, output to LCD, etc.) to free the main Stamp to do stuff that relies on speed, such as reading various sensors and updating all the servo pulses.
I hooked up the 2 stamps as described in www.parallax.com/Portals/0/Downloads/docs/prod/stamps/web-BSM-v2.2.pdf under the SERIN command (page 410 in my version). For the longest time I considered this to be some dark ancient art and had to study humanoido's projects to figure it out, but then of course, as usual, it was right there, under my nose, in the manual... Anyway, made that work, but there's a catch:
Because there's no buffer, the transmitting Stamp has to transmit for a while, until the receiving Stamp gets the message, and, the receiving Stamp has to constantly listen in order not to miss the message. That makes things kind of sluggish, and only works well for those who are versed in the dark art of subsumption programming.
So I came up with this idea, but I paid too much for my Stamps (wish I knew about the recent $50 sale...) to blindly experiment with them, so I need your kind expertise:
Is is possible to hook up both Stamps to one Eeprom chip (same chip) via I2C to do the following (basically act as a simple buffer):
The main Stamp sends a command to the Eeprom (just some text string) and changes a "trigger" bit from "0" to "1", then immediately goes about its business. The secondary Stamp, checks the "trigger" bit on the Eeprom at pre-programmed intervals, or whenever it's done doing whatever it was doing. Then, if it sees that the "trigger" was tripped to "1", read the command stored in the Eeprom and execute it. I suppose, in a further step, it would be even possible to construct a FIFO queue of sorts, maybe even with priorities, so if there are 3 commands waiting in a queue, but only one is very important (for example, one needs to update a sensor status on an LCD, the other 2 just speak funny stuff, the status update takes priority), the other 2 are either discarded or moved to the end.
I guess my long(ish) question can be broken into pieces:
1. Is it possible to have 2 masters (I know the Stamp cannot be a slave) on the same I2C line.
2. If 1 is yes, what is the correct way to physically wire this up.
As always, thanks for your kind guidance.
modemman
modemman
Single 8 bit commands should be sufficient.
Thanks.
modemman
Thanks Phil.
Here is a circuit (untested) that should work for you. Resistor values in the neighborhood of 4.7K should work fine here:
It works like this:
1. The slave tristates RCVCLK then pulses the /ACKIN pin low to clear the shift regster.
2. Whenever the master (left side) wants to send a command to the slave (right side), it embeds the 6-bit command between "1" bits (%1cccccc1) and sends it via SHIFTOUT, using the XMTCLK and XMTDAT lines. Then it leaves XMTCLK low, and tristates XMTDAT.
3. The slave, once it sees a "1" bit on RCVDAT, knows that a command is in the shift register ready to be clocked in; so it uses RCVCLK and RCVDAT to do that, using SHIFTIN. While it's doing this, QA keeps getting fed back to XMTDAT. Since it was a "1", it remains a "1".
4. Go back to step 1. This immediately clears QA and QH, which tells the master that the slave received the data, and tells the slave that there's no new data in the shift register.
Post Edited (Phil Pilgrim (PhiPi)) : 5/29/2009 9:07:13 PM GMT
Thanks.
modemman
Tracy Allen
www.emesystems.com
Hmm, yes, a multi-master system would work with the Stamp if a flow control scheme were implemented with extra Stamp pins or with an I/O pin on the slave device itself, which could be set and cleared. I'm trying to imagine how collision would work, though, since the PBASIC firmware is not designed to support it.
humanoido
Post Edited (humanoido) : 5/30/2009 8:50:09 PM GMT
It is not for all purposes. But flow control options along with timeouts of a little as one millisecond can make things a lot less sluggish when two Stamps talk.
Tracy Allen
www.emesystems.com
