Antenna for Parallax RF Set
I purchased the Parallax RF transmitter (27980) and receiver set (27981). I am not getting anywhere close to the 500' range.· I was thinking about switching the 1.5" antennas that comes with the set with 6" 433mhz antennas from digi key. Has anyone tried to increase the range by increasing the antenna size, if so does it work and how much more range will it pickup?·· Thanks Bob
First I put the antenna on top of the garage roof. That was not a good idea as the transmitter seems to be very senitive to static electricity. I killed two transmitters due to heavy hail showers last winter. So I decided to put the antenna down under the cealing instead and so far my transmitter still works despite some thunderstorms lately.
Attaced is one image of the antenna and the other show the 433 transmitter in the metal candy box.
KjellO
Post Edited (Moskog) : 5/29/2009 7:33:51 AM GMT
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Is that a tin (Steel) roof over your antenna?
If so it also acts like an attenuator and will reduce range.
If the transmitter is talking to one receiver then a good directional antenna will improve the range. No sense radiating power in directions away from the receiver.
Look at Yagi antennas in the ARRL Handbook. If you dont want to buy one maybe any of your Ham Radio friends may have one to look at.
Alan Bradford ·N1YMQ
Plasma Technologies
Canaan NH 03741
www.plasmatechnologies.com
I’ve been playing with the same Links chips that Parallax used to fit to their transceivers (different frequencies though) and I get a lot more than double the 3000 feet specified for the IC. I’ve got reliable comms over 2.5Km (7500 feet) but I live in the African Veldt far away from any electrical or wireless interference so I assume the RF noise “floor” round here is exceptionally low.
Antellas are critical... Even 10mm shorter or longer makes a difference. Visit the Links site and read the datasheet on
http://www.linxtechnologies.com/Support/Application-Notes/
AN-00501 - Understanding Antenna Specifications and Operation. This ·gives all the dope for the·antenna on the parallax module.
The receiver also comes with a signal strength port. You should be able to measure the difference between when you’re transmitting and when not (the RF noise floor) and see roughly how efficient different antennas are.
But I warn you, RF is a black art. RF engineers are more confusing that the African witchdoctors. They talk of signals leaking and corners being too sharp, They tell you some RF law then say “but it doesn’t always apply”. ·Sometimes things work, sometimes they don’t. That’s why it’s usually wiser to buy an RF module complete with antenna rather that spending hours/days/months/years/lifetimes fiddling…
The tin should help so don't throw it away just yet (see the comments in the Links·notes on ground planes). Remember that each antenna is frequency specific so it won't help to use a ham antenna. There are Yagi's for 433 Mhz and·using one·on the receiver should·give you a good improvement, using one on the transmitter·could make the signal too strong to comply with FCC which would then make your device illegal in the USA.
If you do come up with a revolutionary antenna, patent it first then let us know.
Kind regards from Kwa Dukuza in South Africa
John Bond
Post Edited (John Bond) : 5/29/2009 12:06:13 PM GMT
Alan, no its not a steel or metal roof, its a kind of old fasion roof material including asbestos and other stuff, I don't think it affect radio·waves much. And in my case I cant use an antenna that is too directional because this transmitter is talking to two recievers in two very different directions. So this solution works for me but I'm sure a different solution, maybe a yagi as John mention, would fit better for Bob starting this thread.
KjellO
Post Edited (Moskog) : 5/29/2009 1:26:57 PM GMT
If you think about it, an end-fed 1/2 wave antenna is really an end-fed dipole, but it obviously has to be properly matched to the feeder to be effective.
Leon
Post Edited (Leon) : 5/29/2009 2:08:12 PM GMT
Leon, I do appreciate your advices on antenna design, guess I will try a 1/4 wave pin with radials instead.
So, in Bob's case, to help increase the range of his transmitter, he could solder a 50 ohm coax (like RG58 or so) to the TX module, or use a connector, and then connect a 1/4 wave antenna at the other end of the cable.
I found a calculator for such antennas here:
http://www.csgnetwork.com/antennagpcalc.html
I also found a description on how to make a simple antenna here:
http://www.mattstuff.nq.nu/antennas/quarter-wave.html
I do think the output impedance of the TX module is obout 50 ohm, the center core of the coax should be connected to the square where the original antenna is mounted, the shield should be connected to the ground or minus connector. At the other end the center core should be connected to the vertical pin, the shield to the four radials.
Leon
Post Edited (Leon) : 5/29/2009 4:12:14 PM GMT
