Multiple Inputs / Outputs on 1 pair
Quick question,
I have a situation where I have multiple alarm sensors (switches) on a roof, but only 1 available pair going down to the alarm panel (Prop based).
I was thinking of making a small board which would recieve these inputs...transmit the data over the 2 wires down to another small board which would re-expand these to the alarm panel inputs.
Would using a propeller at each end be overkill?
The existing cable is telephone cable travelling 30 floors (390ft).
Rick
Rick
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I was thinking of using a 4021 on the sensor side and a prop on the recieving/expanding side..but I believe that would require 3 wires (clock/data/latch).
Rick
Post Edited (CassLan) : 5/28/2009 9:05:25 PM GMT
I don't know that much about them, but I'm pretty sure you can get them in I2C and other two wire interfaces. Of course depending on how far away the switches were from the alarm panel you might have trouble with the serial communications.
PHRED, FIRST Team 847, Member
Go -> PHRED
I was looking at the MCP23008-E/P (http://ww1.microchip.com/downloads/en/DeviceDoc/21919e.pdf)
I will give it a shot!
Rick
You could always do something like this - use one wire for ground, and the other for data/clock all rolled into one. From there, it's a simple matter of making your own protocal.
And yes, a Propeller is overkill, but at $8 a pop, so what? [noparse];)[/noparse]
Jim
I actually built a project that used a 5 volt signal and it was good for about 20 meters. The wires were typical parallel cables (shielded), but it worked fine at those distances. At 3.3 volts, I probably wouldn't go over 10-12 meters.
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Please note: Due to economic conditions the light at the end of the tunnel will be turned off until further notice. Thanks for your understanding.
Rick
