nRF905
I am trying to get a SX28 to talk to a nRF905 single-chip radio transceiver, I have some C code can any one have a look at the code and tell me how to convert it to the SX.
void InitPort(void){
// Port I/O configuration: 0=output, 1=input
TX_EN_TRIS = 0; //TX_EN
ADPCFGbits.PCFG6 = 1;
TRX_CE_TRIS = 0; //TRX_CE
ADPCFGbits.PCFG7 = 1;
PWR_UP_TRIS = 0; //PWR_UP
ADPCFGbits.PCFG8 = 1;
CD_TRIS = 1; //CD
ADPCFGbits.PCFG9 = 1;
AM_TRIS = 1; //AM
ADPCFGbits.PCFG5 = 1;
DR_TRIS = 1; //DR
ADPCFGbits.PCFG4 = 1;
CSN_TRIS = 0; //CSN
// nRF initial modes
TX_EN = 0; // Rx mode
TRX_CE = 0; // Standby mode
PWR_UP = 0; // Power down
CSN = 0; // Chip Select Not = enabled
void InitSPI(void)
OpenSPI1(FRAME_ENABLE_OFF&ENABLE_SDO_PIN&SPI_MODE16_OFF&
SPI_SMP_OFF&SPI_CKE_ON&SLAVE_ENABLE_OFF&CLK_POL_ACTIVE_HIGH&
MASTER_ENABLE_ON&SEC_PRESCAL_1_1&PRI_PRESCAL_1_1,
SPI_ENABLE&SPI_IDLE_CON&SPI_RX_OVFLOW_CLR);
DisableIntSPI1;
unsigned char Spi1WriteRead(unsigned char in)
unsigned char out;
SPI1STATbits.SPIROV = 0;
SPI1BUF = in;
while(!SPI1STATbits.SPIRBF);
out = SPI1BUF;
return out;
void InitNRF(void){
int i;
nRFConfig[noparse][[/noparse]0] = CH_NO_BYTE; //Sets center frequency together with HFREQ_PLL
nRFConfig[noparse][[/noparse]1] = PA_PWR_10dBm|HFREQ_PLL_433MHz|CH_NO_BIT8; //Output power, Band 433 or 868/915 MHz
nRFConfig[noparse][[/noparse]2] = TX_AFW_4BYTE|RX_AFW_4BYTE; //Tx and Rx Address width
nRFConfig[noparse][[/noparse]3] = RX_PW_32BYTE; //RX payload width
nRFConfig[noparse][[/noparse]4] = TX_PW_32BYTE; //Tx payload width
nRFConfig[noparse][[/noparse]5] = nRFAddress[noparse][[/noparse]0];
nRFConfig[noparse][[/noparse]6] = nRFAddress[noparse][[/noparse]1];
nRFConfig[noparse][[/noparse]7] = nRFAddress[noparse][[/noparse]2];
nRFConfig[noparse][[/noparse]8] = nRFAddress[noparse][[/noparse]3];
nRFConfig[noparse][[/noparse]9] = CRC16_EN|XOF_16MHz; //CRC check. Crystal oscillator frequency.
PWR_UP = 1;
CSN = 1;
CSN = 0;
Spi1WriteRead(WC); //Write nRF configuration
for(i=0;i<10;i++)
Spi1WriteRead(nRFConfig[noparse][[/noparse]i]);
CSN = 1;
CSN = 0;
Spi1WriteRead(WTA); //Write TX Address
for(i=0;i<4;i++)
Spi1WriteRead(nRFAddress[noparse][[/noparse]i]);
CSN = 1;
TRX_CE = 1;
void TXPacket(char *packet){
TRX_CE = 0;
TX_EN = 1;
int i;
CSN = 0;
Spi1WriteRead(WTP); //Write TX Payload
for(i=0;i<32;i++)
Spi1WriteRead(packet[noparse][[/noparse]i]);
CSN = 1;
TRX_CE = 1; // Start transmitting
while(!DR); // Wait for transmission to finish
TX_EN = 0;
void RXPacket(void){
int i;
char SpiRxBuf[noparse][[/noparse]32];
TRX_CE = 0;
CSN = 0;
Spi1WriteRead(RRP); //Read RX Payload
for (i=0;i<32;i++)
SpiRxBuf[noparse][[/noparse]i] = Spi1WriteRead(0);
CSN = 1;
TRX_CE = 1;
if(SpiRxBuf[noparse][[/noparse]0] == 'o' && SpiRxBuf[noparse][[/noparse]1] == 'n'){
green_led = 1;
else if(SpiRxBuf[noparse][[/noparse]0] == 'o' && SpiRxBuf[noparse][[/noparse]1] == 'f' && SpiRxBuf[noparse][[/noparse]2] == 'f'){
green_led = 0;
else USBsend(SpiRxBuf);
I have tryed the Shiftout and Shiftin but have had no luck, I need a SPI.
Glenn
CD_TRIS = 1; //CD
AM_TRIS = 1; //AM
DR_TRIS = 1; //DR
CSN_TRIS = 0; //CSN
void InitSPI(void)
DisableIntSPI1;
unsigned char out;
SPI1BUF = in;
out = SPI1BUF;
return out;
void InitNRF(void){
int i;
PWR_UP = 1;
CSN = 1;
CSN = 0;
for(i=0;i<10;i++)
CSN = 1;
CSN = 0;
for(i=0;i<4;i++)
CSN = 1;
TRX_CE = 1;
TRX_CE = 0;
TX_EN = 1;
int i;
CSN = 0;
for(i=0;i<32;i++)
CSN = 1;
TX_EN = 0;
int i;
TRX_CE = 0;
CSN = 0;
for (i=0;i<32;i++)
CSN = 1;
TRX_CE = 1;
green_led = 1;
green_led = 0;
Glenn
Best bet might be to post:
- your SX/B or ASM code that failed
- the data sheet for the slave device
I have added all the files and code I have, I am trying to use the nRF905-C868. I hope this will help some one find out how to use the SX28 and the nRF905.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Glenn
Leon
Leon
