NTSC video monitor - What do you use with the Propeller?
I'd like to interface the Propeller to an LCD video (NTSC) monitor a bit
larger than the 3.5 inch display offered by Parallax, but not too much
pricier.
What are some specific models folks here have been using
and are happy with? (Display size and URL link if available)
phil
pricier.
phil
- second screens for dvd players
Largos - a nano operating system for the Propeller
www.mikronauts.com - a new blog about microcontrollers
Exactly the type of info I was looking for. I had done some Google
searching, but unless one knows the right question to ask and key
phrases, Google doesn't help much.
phil
Another great option is a USB capture device. There is some latency on these. It's about 300-600ms, on average, but the upside is having a nice window on the PC to see display output from the Propeller. This makes a propeller rather portable. Toss it in a laptop bag, and call it good.
The HDTV capable ones do a very nice capture. You get the full 720x486 NTSC frame. This is very handy for drivers and such as the full overscan can easily be seen.
I recently tried the PAL option, and it appeared to work just fine. (and there are a lot of PAL options!! Most look the same, so I'm not sure what's up with that.)
It's nice to have both standards for viewing projects.
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
Safety Tip: Life is as good as YOU think it is!
Here is a 7" flatscreen model that looks pretty interesting.
Second-hand stores and thrift shops are another source of bargain TVs with A/V inputs.
Just make sure whatever you buy has a a/v in switch for direct drive.
······· "What do you mean, it doesn't have any tubes?"
······· "No such thing as a dumb question" unless it's on the internet
the comments you all have offered.
I'm not familiar with that device. Could you elaborate a bit, please.
phil
Post Edited (phil kenny) : 5/28/2009 6:13:45 PM GMT
When my old 5" b/w CRT monitor died, I ran across a Sony FX810 model. 8" screen, A/V inputs (which was mandatory; cheaper units don't seem to include). About $100. Is nice to have a 'color monitor'. Plays CD/DVDs too.
Harley Shanko
OBC
New to the Propeller?
I got a DVP-FX810, a pretty high end 8" model, for $20 with shipping because it was advertised as playing (including DVD's) from battery but neither charging the battery nor running from AC. I opened the unit and hotwired an AC adapter to the battery contacts, and it works beautifully.
I think that's the exact one I have. Over the air HDTV is excellent, and it will record MPEG video right to the hard disk. I rarely use that function. Depending on the model you buy, it does S-video along with ordinary composite baseband video capture, NTSC, PAL and other formats.
All you do is plug it in to the USB, fire off the capture application, connect your prop, and see the video output in a window on your PC. There is a frame capture function that I use all the time. Good for communicating between people. I've several screen captures posted to this forum you can see as samples.
If that's not a worry, the rest is all good. Signal tolerance is good, resolution, the whole deal. I find the thing is very helpful when doing video driver work. A capture device will put up with a lot that a TV might not.
John Abshier
"VOOM"?!? Mate, this bird wouldn't "voom" if you put four million volts through it! 'E's bleedin' demised!
