IC Driver, MC14489BP and the Propeller
Can someone please give me an example·code for sending the information from the propeller to the MC14489 in order to display a "score" on the 16 segment LED on the PPDB.· This is just for my own use.· So far I have writen code and used some other peoples code to display "Bumpper1" and "Bumpper2" on a VGA monitor when 1 of 2 buttons on the PPDB are pressed...now what I would like to do is everythime I hit one of the buttons it displays a 10 on the 16 segment LEDs and whenever you hit the same button it adds 10 to the the previous score.
I know this chip is used for 7 segment LEDs but I dont need all 16 segments so I thought this would work just fine for now. This is just me·trying to write code·for a pinball machine I am going·to build later I'm just using the PPDB as a test platform for the code. I will post what I have on here so far if anyone would like to see.· Like I said right now all that happens so far is when button 1 or 2 are hit "Bumpper1" or "Bumpper2" are flashed up on the screen and a "ring" sound is made...When button 3 or 4 are hit "Flipper1" or "Flipper2" are flashed up on the screen to repersent the Bumppers or Flippers where activated. Now I would just like to use the LED segments to display a score.
now there's a week over with no answer-postings to your question
I think I know the reason.
There is not a single line of code from YOURSELF.
All the information you gave was the serial number of the chip MC14489.
This means it is a great effort for forum members to give an answer
1.) find a download page for the chip
2.) download the datasheet
3.) start reading in the datasheet
4a.) write some code with no possability for really testing it
4b.) buy the chip to be able to test some code for it
I hope you can see this is an initial effort almost nobody wants to take
If you break down the problem to
"here is a picture of the timing diagram showing the clock and dataline (attach a picture from the datasheet)
I tried the following code but nothing happens - what am I doing wrong ?"
I think you will get answers
I'm sure you are NOT that type of guy but some even MIGHT think you are someone "I don't kow it - do it for me"
Another solution would be to use 74HC595-serial shiftregisters to control all the pins of the 16segment-displays
for 74hc595-shiftregisters there is code in the obex
and if you come up with a detail-question with your code attached you will get a lot of answers
So come up with your first lines of code asking a concrete question
best regards
Stefan
···· I'll post the code I have when I get home...I've been posting all of this from work.· I dont have any code for the LED segments cause I have no clue how to write it...All the code thats working the LEDs are for the BS2 using SERIN and SEROUT...and thats what I'm trying to figure out how do I write a SEROUT command for the propeller.
