Is there any technical problem to add in additional HS-422 Servos?
I would like to modify HexCrawler by adding in 2 more HS-422 servos, so the Hexcrawler will have 14 HS-422 servos.
Do you think existing combination of BS2 controller, LCD AppMod,·BoE·still can·be·configured to make·all 14·HS-422 servos to move at the same time?
Is it necessary to increase·the power· to support movements of all 14 HS-422 servos?
- Stephen
